Does the Sasquatch camera stick out further?
zedster
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
Before I ask my question, yes I used the search and did not find my answer. Does the Saquatch camera stick out further? If so is it possible to make the stick shorter? I am having issues with mine and my trailer's power jack. I have to remove the tire and the tire carrier when the trailer is connected.
Oldhippie
Barry
Santa Cruz, Calif.
Hitch extension??
zedster
zedster
Las Vegas
zedster
zedster
Las Vegas
Ford Bronco Does the Sasquatch camera stick out further? 20220130_102211
Ford Bronco Does the Sasquatch camera stick out further? 20220130_102220
dgorsett
colorado
F250, Mustang, Explorer
Just a thought: If the mounting holes (3) on the jack are an equilateral triangle, could it be rotated so the 'swell' on the jack head was oriented to the side? I suppose holes could be re drilled if needed?
Ford Bronco Does the Sasquatch camera stick out further? 1643576423133
zedster
zedster
Las Vegas
Thought of that as well but I am pretty sure it can not be moved to the side. I need to get an antisway setup and a lot of those extend it out. I hope that helps. Even maybe buying the spare tire relocation to move the tire up 2 inches.
Raptor911
Raptor911
Broadlands, VA
The SAS camera does stick out further. Watch the video below as they talk about it
dgorsett
colorado
I'm suggesting rotating the entire jack 120 degrees. But, yeah also equalizer set up may do it
zedster
zedster
Las Vegas
CHR1S
Ft Carson CO.
Okay, I saw you had factory hitch, but I thought you could easily swap for the extension and not lose the capacity. You already have the wire harness, so it would be easy to unbolt and throw the longer one on, and it would clear the spare tire. All good, just throwing out ideas for you.
zedster
zedster
Las Vegas
I appreciate that. Thank you. Just seems like Ford didn't think too hard on some of this towing stuff.
Lifeliberty
Moonbeam👀
Columbus, OH
I'd probably get a different jack before i ditched my spare
zedster
zedster
Las Vegas
