Does the Bronco Raptor have IWE - Integrated Wheel Ends?
Laminar
Iowa
Cougar
I remember the press releases mentioned the BRaptor had front knuckles based on the F-150. In watching Autopian's video of the BRaptor, I noticed the old vacuum-style IWE on the inside of the knuckle:
Ford Bronco Does the Bronco Raptor have IWE - Integrated Wheel Ends? 1664398525308
Visible at 5:48 in this video:
Is this a pre-production or display unit fluke, or does the BRaptor actually have IWEs?
dgorsett
colorado
F250, Mustang, Explorer
It is my belief (not knowledge) that all broncos with Advanced 4x4 do not have FAD or IWE.
Deleted member 31057
Guest
Ford Bronco Does the Bronco Raptor have IWE - Integrated Wheel Ends? Screen-Shot-2022-06-20-at-9.14.17-AM-1024x577
Ford Bronco Does the Bronco Raptor have IWE - Integrated Wheel Ends? Screen-Shot-2022-06-20-at-7.37.08-AM-1024x563
Ford Bronco Does the Bronco Raptor have IWE - Integrated Wheel Ends? Screen-Shot-2022-06-20-at-9.39.36-AM-1024x583
Some pictures to help you make your decision.
If you've ever worked on F150's you know what the IWE is. After 190k on mine I finally had to change one.
Laminar
Laminar
Iowa
Cougar
My computer was acting funky yesterday and I was trying to post the thread before restarting. Here's the part I'm talking about:
Ford Bronco Does the Bronco Raptor have IWE - Integrated Wheel Ends? 1664453713587
This is clearly a vacuum-style IWE from the F-150.
Ford Bronco Does the Bronco Raptor have IWE - Integrated Wheel Ends? Ford_F150_IWE_hub
Here's the Badlands from parts.ford.com:
Ford Bronco Does the Bronco Raptor have IWE - Integrated Wheel Ends? 1664454195952
No splines on the axle to engage with the IWE, just inner splines to engage with the hub at all times.
Here's an F-150 axle designed to be used with an IWE, note the large square splines on the outside but smooth outer shaft with no splines:
Ford Bronco Does the Bronco Raptor have IWE - Integrated Wheel Ends? 1664454268164
Here's a picture from an OBX Bronco showing no IWE, just an aluminum spacer:
Ford Bronco Does the Bronco Raptor have IWE - Integrated Wheel Ends? 1664454973894
So back to my original question, since the BRaptor mockup clearly has a vacuum IWE: Was that a pre-production fluke, or does the BRaptor actually have IWEs?
vrtical
Doug
GSMNP, TN
Fords
oh thats interesting.
T Copp
Travis
KC
Bronco, Mercedes GLB
Current view of my Raptor.
Ford Bronco Does the Bronco Raptor have IWE - Integrated Wheel Ends? D2923C43-DA21-4A70-B044-F226C69147D5
MNbronco
RC
SE MN
2021 F150 Tremor, 2021 Bronco sport
New F150 and I believe bronco no longer use vacuum IWE, but instead is electronically controlled. Sure looks like a spot for vacuum hose on Braptor, could look under hood to see if vacuum solenoid is there?
Sixtysixpride
Zach
Mi
Ranger
Don’t quote me the the Bronco Raptor was supposed to have literally dropped in F-150 Raptor components in the front suspension/driveline. Things were modified here and there to adapt to a Bronco platform but were otherwise recycled parts.
flip
Phil
IN
www.ruxerparts.com
Fords
Holy crap...took forever to find but yes, they did put IWEs on them, WTF.
System Operation
IWE System
IWE System Vacuum Diagram 3.0L
Ford Bronco {thread} {filename}
ItemDescription
1Brake booster
2Vacuum pump
3IWE vacuum reservoir
4IWE solenoid
5IWE vacuum actuator LH
6IWE vacuum actuator RH
The IWE system consists of the following:
1IWE s (spring-loaded vacuum hubs)
2Vacuum hoses
3IWE solenoid
4Vacuum reservoir
The IWE system uses a vacuum solenoid and vacuum actuated hubs to engage or disengage the front wheel hubs from the front half shafts.
When the 4WD system is in 2WD (2H) mode, the AWD module supplies a ground path to the IWE solenoid to apply engine vacuum to the IWE s thus disengaging the front hubs from the front half shafts. To maintain vacuum during all modes of engine operation, a one way vacuum check valve and a vacuum reservoir are positioned between the vacuum source and the IWE solenoid.
When operating in any 4WD mode, the AWD module does not supply the ground path to the IWE solenoid. Vacuum is not applied to the IWE . An internal spring keeps the IWE clutch ring engaging the front hub and the front half shaft.
The AWD module has two startup strategies that affect IWE operation after initial key cycle:
  • When ambient temperature is below 32 F (0 C), the IWE engage after initial key cycle and a driven gear is selected. The hubs stay engaged regardless of a 4x4 mode change for approximately 2 miles (3km). Once the set distance has been achieved, the IWE disengage (if the vehicle is in 2WD (2H)). Distance traveled resets only if the temperature is below calibrated threshold and another key cycle occurs or if customer shifts to Park (P) and back to a driven gear within the same key cycle. The AWD module uses this strategy to warm up the front axle in cold temperatures to improve driveline synchronization.
  • When ambient temperature is above 32 F (0 C), the IWE engage after the initial key cycle and a driven gear is selected. The hubs stay engaged regardless of a 4x4 mode change for approximately 0.5 miles (0.8km). Engagement only occurs once per key cycle and is not reset when shifting between Park (P) and Drive (D). The AWD module uses this strategy to delay vacuum use until vacuum-intensive engine startup has completed and sufficient vacuum is available to fully disengage the IWE .
Four-Wheel Drive
The 4WD (four wheel drive) systems consists of:
  • Transfer case
  • Driveshafts
  • IWE
  • Front axle
  • Rear axle
  • AWD module
  • ATCM
The transfer case has five modes of operation:
  • 2H - Two-wheel drive high
  • 4A – Four-wheel drive auto
  • 4H - Four-wheel drive high
  • 4L - Four-wheel drive low
  • Neutral – For recreational flat towing
(2H) OPERATION
When the ATCM is in (2H), power is delivered to the rear wheels only. This mode is appropriate for normal on-road driving on dry pavement and provides the best fuel economy. Torque is passed through the transfer case to the rear driveshaft at a 1:1 ratio. In (2H):
  • The ATCM sends a (2H) mode status to the AWD module via the GWM .
  • The transfer case clutch is at or below the kiss point.
  • The reduction sleeve connects the input shaft and output shaft
  • (2H) will momentarily be displayed in the message center at key up and after a 4WD to (2H) shift.
(4A) OPERATION
When (4A) is selected on the ATCM , the 4WD system provides electronically controlled four-wheel drive with power delivered to all four wheels, as required, for increased traction. (4A) is appropriate for all on-road driving conditions, such as dry road surfaces, wet pavement, light snow or gravel. Shifts from (2H) or (4H) to (4A) can be made at any speed. In (4A):
  • The ATCM sends a (4A) mode status to the AWD module via the GWM .
  • The shift motor positions the ball ramp device at the clutch kiss point when driving conditions do not require 4WD .
  • The shift motor positions the ball ramp device to apply the clutch when wheel slip is anticipated or detected.
  • (4A) is displayed in the message center.
AUTOLOCK
If the system is in (4A) and AWD module detects driving conditions that require greater 4WD performance, the AWD module temporarily turns on (4H). The message center displays 4X4 TEMPORARILY LOCKED. The 4WD system automatically returns to (4A) after the system no longer detects these driving conditions. The message center will temporarily display 4X4 RESTORED.
POWERTRAIN TORQUE PROTECTION
If the system is in (4A) and AWD module detects excessive stress or high energy going through the clutch (clutch is slipping excessively while the system is commanding max clutch torque), the shift motor will release the clutch and message center indicates 4x4 TEMPORARILY DISABLED. When the system had the ability to cool off, 4x4 operation will be automatically restored. The message center will temporarily display 4X4 RESTORED.
(4H) OPERATION
(4H) provides electronically locked four-wheel drive power to both the front and rear wheels for use in off-road or winter conditions such as deep snow, sand or mud. This mode is not for use on dry pavement. Shifts from (2H) to (4H) can be made at any speed. In (4H):
  • The ATCM sends a (4H) mode status to the AWD module via the GWM .
  • The shift motor positions the ball ramp device to completely apply the clutch.
  • (4H) is displayed in the message center.
(4L) OPERATION
(4L) provides electronically locked four-wheel drive power to both the front and rear wheels for use on low traction surfaces but does so with an additional gear reduction for increased torque multiplication. Intended only for off-road applications such as deep sand, steep grades or pulling heavy objects. (4L) does not engage when your vehicle is moving above 3 mph (5 km/h); this is normal and should be no reason for concern.
Shifts to and from (4L) can only be made below 3.1 mph ( 5 km/h) with the transmission in Neutral. When performing this shift, wait until the 4x4 Shift in Progress message disappears in the IPC before moving the selector lever back to Drive. If the vehicle speed or transmission range is not within parameters, the message center will indicate the necessary action needed to complete the shift. In (4L):
  • The ATCM sends a (4L) mode status to the AWD module via the GWM .
  • The shift motor positions the reduction sleeve connecting the planetary carrier and output shaft
  • (4L) is displayed in the message center.
NEUTRAL OPERATION
For recreational towing (all 4 wheels on the ground) the transfer case should be placed in Neutral.
Refer to: Neutral Flat Tow Activation and Deactivation (307-07B Four-Wheel Drive Systems - Advanced 4x4 with 4A Mode, General Procedures).
  • The IPC sends a Neutral mode status to the AWD module via the GWM .
  • The shift motor positions the reduction sleeve to only engage the output shaft
  • “Neutral Tow Enabled” is displayed in the message center.
G.O.A.T. Modes
NOTE:
Not all G.O.A.T. modes are available in each trim level.
The vehicle is equipped with Goes Over Any-type of Terrain (G.O.A.T.) Modes that allows the driver to enhance the off-road performance of the vehicle by selecting the mode best suited to the terrain and driving conditions. Each mode changes a number of the vehicle parameters within the engine, transmission, traction control and 4WD systems.
Normal
  • For everyday driving. This mode is the perfect balance of excitement, comfort and convenience. This is the default mode after each ignition cycle, the driveline settings remain the same prior to the ignition cycle.
  • (2H) is the default four-wheel drive mode. All four-wheel drive modes are selectable when in normal mode.
  • The front electronic locking differential, is available when in (4L).
  • The rear electronic locking differential, is available.
  • The stabilizer bar disconnect is available if (4H) or (4L) is selected.
Eco
  • For efficient driving. This mode helps deliver maximum fuel efficiency and helps to increase driving range.
  • (2H) is the default four-wheel drive mode. (4L) is not selectable in eco mode.
  • The front electronic locking differential is not available in eco mode.
  • The rear electronic locking differential is available.
  • The stabilizer bar disconnect is not available in eco mode.
Sport
  • For sporty driving with improved performance handling and response. This mode increases accelerator pedal response and provides a sportier steering feel. The powertrain system holds onto lower gears longer, helping your vehicle accelerate faster.
  • (2H) is the default four-wheel drive mode. (4L) is not selectable in sport mode.
  • The front electronic locking differential is not available in sport mode.
  • The stabilizer bar disconnect is not available in sport mode.
Slippery
  • For less than ideal road conditions such as snow or ice covered roads. This mode can be used for crossing terrain where a firm surface is covered with loose, wet or slippery material. Slippery mode lowers throttle response and optimizes shifting for slippery surfaces.
  • (4H) is the default four-wheel drive mode. Both four-wheel drive modes are selectable in slippery mode.
  • The front electronic locking differential is available when in (4L).
  • The stabilizer bar disconnect is not available in slippery mode.
Sand
  • For off-road driving on soft, dry sand or deep snow. This mode may help get your vehicle unstuck from deep snow or sand.
  • (4H) is the default four-wheel drive mode. (4L) is selectable in sand mode.
  • The rear electronic locking differential is engaged when in sand mode and is available in all selectable four-wheel drive modes.
  • The stabilizer bar disconnect is available in (4H) or (4L).
Mud/Ruts
  • For off-road driving. This mode enhances vehicle performance to traverse muddy, rutted or uneven terrains.
  • (4H) is the default four-wheel drive mode. (4L) is selectable in mud/rut mode.
  • The front electronic locking differential is available when in four-wheel drive low.
  • The rear electronic locking differential is engaged when in mud/ruts mode.
Rock Crawl
  • For off-road driving and optimum rock-climbing ability. Rock crawl mode optimizes the throttle and transmission response to provide you additional control of your vehicle.
  • (4L) is the only four-wheel drive mode selectable in rock crawl, the system prompts you to put your vehicle into (4L) upon selection.
  • The rear electronic locking differential is engaged when in rock crawl mode.
  • The stabilizer bar disconnects when in rock crawl mode.
Baja
  • For high speed off-road driving. Baja mode optimizes the throttle control for better response and torque delivery.
vrtical
Doug
GSMNP, TN
Fords
I had IWE on my 2019 F150 and there are some procedures notes for it that owners should read.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
I take it that is a vacuum line going in:
Ford Bronco Does the Bronco Raptor have IWE - Integrated Wheel Ends? 5BC30CE2-CC47-4801-84D7-5B9D8402B89A
Ford Bronco Does the Bronco Raptor have IWE - Integrated Wheel Ends? A019A053-1702-47F6-B9CD-D817C29D171C
Ford Bronco Does the Bronco Raptor have IWE - Integrated Wheel Ends? 5241E2CE-A8FE-480C-97E2-D1E8AFA703BE
Laminar
Laminar
Iowa
Cougar
Are these pictures from your BRaptor??
You're correct - the larger one is the vacuum source that pulls the actuator back and disengages the hub from the axle. The smaller tube is the vent that allows the displaced air someplace to go. I will just be an open vent tube somewhere around the frame rail.
Dads_bronze_bronco
Yes - these are from my delivered production BRaptor this morning.
