Does the 2.7L Ecoboost require premium gas?
Laminar
Iowa
Cougar
This used to not be the case even 10 years ago. Knock detection and prevention systems were much more rudimentary and designed primarily to prevent catastrophic failure. In engines like those using a fuel type with octane ratings higher than recommended by a manufacturer was pointless because the engine simply could not utilize the extra detonation resistance.
So many people repeating the same BS they heard from their "car expert" uncle Cooter who drives an '87 Camaro and has no clue how modern stuff works.
As far as premium fuel being cleaner than regular. That's horseshit.
(y)(y)(y)
wjfawb0 [hacked account]
Tennessee
2015 Jeep Wrangler JKR
What Laminar and Internally_Combusted said. Higher octane gas like 91/93 and especially E85 resist detonation by having higher flash points. You can run higher pressure and temperatures without preignition. Turbo cars can also use the wastegate to regulate boost levels along with the dynamic compression of the engine using the variable valve timing adjustments. Spark and fuel timing can be retarded and advance too, on an individual cylinder basis.
It's not uncommon for stations in my area to offer 100% gasoline 0% ethanol fuel. I've used it in many of my cars (5.4 F150, 5.0 Mustang, 3.6 Wrangler) and almost always get about 10% better mpg highway. That's not really a surprise because ethanol doesn't contain the same amount of energy as gasoline per volume. E85 compatible vehicles have to have injectors large enough to supply enough of the fuel to hit stoich air fuel ratio. Gasoline is around 14.7:1 air:fuel for stoich. E10 is 14:1. E85 is 9.85:1.
https://www.ecmtuning.com/wiki/e85fuel
CCross
Cory
Arkansas
2007 Chevy 2500HD Duramax, 2000 Jeep Wrangler
I have the 2.7l turbo in my MKX and run regular. It puts your head back in the head rest in sport so never a need for premium fuel.
Woo Pig
rtaylor
R
ID
19Raptor, 22Bronco
Title.
Since this motor is turbo'd, should I be running this ? on premium fuel?
If you want to get the advertised power out of the engine, then 93 is required. But the Ford engine computer will learn whatever you are using 87-93 and will operate fine at reduced power. In many areas 93 is not available (only 91 or 92). It is entirely your choice.
If you purchase an after-market tune, they are usually for a specific octane that you specify (the factory octane-learning is disabled), but you are rewarded with higher power. With aftermarket tune, you should never use lower octane fuel than specified by the tune.
Longshot
Nick
2025 F-150 Lightning, 2022 2-Door Bronco
More interested in the cold air intake to boost it... On a side note, glad mine doesn't have the start/stop. I would bypass that as soon as I got home!
Me as well! I held off on the mods on my F-150, but some decent gains can be made on the 2.7... Will definitely be making some on the Bronco!
wvmtneer
‘Merica
F-150
I usually run 87 in my 3.5 ecoboost, but filled up with 89 my past few tanks. Believe it or not, I can definitely feel that the engine drives better, lugs less, etc. i don’t think i’ll go back to 87.
TOWMA8R
Bay Area California
ECOBOOST F150
With adaptive tuning and a turbo, it gets full EPA HP Performance in the highest Octane. If it has a turbo, it will have premium gas in my tank.... IMO
mdonathan56
2022 Bronco Bad,2016 Q5 TDI, 2009 Honda Element EX
If the horse power and torque ratings do not include the caveat "With 91+ octane" you should be good on 89.
Gary
McKinney TX
2018 Raptor
Razorback
Bill
Dallas
Lincoln MKX
what do you mean by this? Im fairly sure the bronco would have start/stop. every other ford seems to, every car on the market really... This link even comments on start stop for the 2.7L.
Not all Ford associated products do. The Lincoln MKX 2.7L doesn't. Could be a good reason they've said no V8 since there would be EPA issues.
Razorback
Bill
Dallas
Lincoln MKX
they added it to the MKX (Nautilus now), not sure what model year, maybe 19MY when the name changed.
That sucks. I did get to thinking that I saw the Overlander build in Tennessee. They drove it out of the unveiling to park with the other Broncos. It didn't start/stop but rather engine ran during all stops, forward and reverse. This is of course a pre-market build, but gives us a significant chance you're not going to be driving a 4x4 that will shut off while rock crawling.
Razorback
Bill
Dallas
Lincoln MKX
was just chatting in another thread about heated steering wheel and there is a clear shot of a start stop button in the controls, so its definitely equipped.
Then there will be a by-pass youtube video on a week from the first one rolling off the assembly line I bet.
Space Cat
James
2020 Jeep Gladiator Rubicon 1st Edition, etc...
Another razorback on the loose... Dadgummit.
