Does anyone know what thread this ground bolt uses?
psdtime
Tom
CA
2026 Bronco
I'm trying to figure out what the thread is used on this ground stud? It's threaded on the outside and I would like to use that for any future additions since I have added so many below it. I know it looks like a nut on threaded stud, but it's actually a bolt with threads extending off of the head. This is the one closest to the battery where the battery's ground lead is attached. Thanks
Ford Bronco Does anyone know what thread this ground bolt uses? 1783102642254-i1
MsPickles
Mi
Went to check for you, but apparently newer models are different. I don't have that stud.
Ford Bronco Does anyone know what thread this ground bolt uses? 20260703_154952
psdtime
psdtime
Tom
CA
2026 Bronco
Probably m6 just eyeballing it. Mine doesn’t have that stud at all though
Ford Bronco Does anyone know what thread this ground bolt uses? imag
psdtime
psdtime
Tom
CA
2026 Bronco
Thanks to all the replies. I just bought a kit of assorted nuts. Hopefully one will fit there, and the others I'm sure will come in handy. Thanks again.
Iceman62
Tim
Omaha, NE
2024 Bronco / Sasquatch
If you have a tap & die set, it should have thread gauges. ;) :D
Motovita
WA/AZ
25 Bronco
It makes no sense to have that stud and attach terminals underneath the bolt head. The thread is probably M6x1.0. If you have 6x1.0 and 8x1.25 you will have nuts for most any fasteners in that size range on your vehicle.
Pops
North of Seattle
2025 2-door, Sas, Mid Pkg.
'got the same thing.
I had a spare nut that happened to fit when I installed this bracket, and just measured it to be M6 x1.0 per Mitutoyo (caliper) -- if this helps anyone.
Ford Bronco Does anyone know what thread this ground bolt uses? batt brkt
This is where I quickly clamp my MORRflate.
psdtime
psdtime
Tom
CA
2026 Bronco
It's a 40 minute drive to a hardware store, so I did what I did with what I had. I don't think it's as igregious as you make it sound, but I plan on moving some back to the other side once I get the correct nut.
KreeHBronco
Kevin
Bay area California
2026 Badland 4-dr Manual
Might be too late, but here is a picture of my 2026 4-dr Badlands with the 2.3L engine compartment. Note that it does have a ground stud vs bolt. Maybe stud vs bolt is model or year dependent. Google AI seems think the thread size is M6x1.0.
Ford Bronco Does anyone know what thread this ground bolt uses? 20260217_140712
psdtime
psdtime
Tom
CA
2026 Bronco
Thanks for all the replies, M6 is the confirmed correct size.
