DIY Hard Top prep kit
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
2022 Ford Bronco Badlands Sasquatch
Looks promising. So, the only difference that I can tell are the pin for plow and the pickup truck icon instead of the Bronco. Which, do any of you have experience changing/removing buttons from controls? I want to assume it’s just a gentle trim tool - pull straight out - kinda thing. I attempted it and it seemed the top portion unclipped easily enough. But, I didn’t want to push it and break it. I’ll go ahead and plug it in and see if it works first.
I think you're venturing out into the unknown at this point. Looking forward to hearing of your successes!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Ugh...I wish I read into the service manual prior to buying this F150 module...now I wonder if the original module can just be programed to activate the rear defrost?
NOTE: If installing a newHVAC module, it is necessary to upload the module configuration information to the scan tool prior to removing the HVAC module.
This information must be downloaded into the new HVAC module after installation.
Is this SCAN TOOL they speak of FDRS?
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
When you do the PMI process in FDRS it'll do all what you're referencing. My personal recommendation would find and install the hvac module intended for a Bronco. But I'm sure that takes all the fun out of it. 🙂
redone17
Cold Spring, NY
I wonder what my dealer would charge to run the PMI process. They’re the only ones that can do it, right?
What does a PMI process do exactly? I’m a n00b when it comes to modern vehicle tech and especially electronics.
Can that scan trick the system into making the mirror defrost button power the grid?
I guess I hastily just expected it to be plug & play.
I guess the number of pre-prep kit standard equipment models in the junkyard are slim.
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
You can do it yourself with this one https://a.co/d/cTMVbsr a copy of FDRS and a 72 hour license, but if you're a noob I'd be careful with what you're messing around with.
You can't just "turn on" the mirror defrost, as it's a bit more complicated than that. As far as what PMI process does, this video explains it well:
redone17
Cold Spring, NY
Thanks @RustysBronco. I got myself pretty well versed in Forscan - but, FDRS seems like a whole other ball field. I will review that video. I don't want to turn on mirror defrost - I want the mirror defrost button to activate the rear defrost grid just like the updated HVAC controls perform. But, I am guessing that is a hardware and software update and my F150 module experiment was a waste of $...
3175375
South Dakota
Will these instructions work with the Turn Off Road Hardtop?
redone17
Cold Spring, NY
Anyone with a standard package 2021 looking for HVAC controls to gain rear defrost? I just bought an entire 2021-2024 Ford Bronco Manual Climate Control Module / Rear Defrost / N2DT19980AC / BR001 from Redline Auto Parts the same week I totaled my truck. As of now I’m looking for a 2025 replacement - so, I won’t need it.
Anyone interested before I put it on Marketplace?
redone17
Cold Spring, NY
Let me know if you need this!
Ford Bronco DIY Hard Top prep kit IMG_2698
Anyone with a Standard Package Pre-Prep Kit Bronco need the correct HVAC controls to activate the rear defrost?
I bought this to finally tackle it this year before winter and I totaled my truck a few weeks ago.
