DIY chase lights installed
Potluck99
Las Vegas
1969 CJ5, 1977 J10, 2022 Lowrider ST
Used some RGB rock lights as chase lights. Mounted them to the rear glass hinge covers. I’m happy with it as they blend in well with the hinge covers.
Ford Bronco DIY chase lights installed 5BE2661C-37FC-4584-8EAC-C8B6209FE337
Ford Bronco DIY chase lights installed FD073326-EC5D-43BA-8FD0-D6FF432226E2
Ford Bronco DIY chase lights installed E5695650-73A0-48F2-8B55-19CB4AE292F2
Ford Bronco DIY chase lights installed C6723F88-ABCA-4A70-99E4-DFCEBE5B8519
kodiakisland
Arkansas
I like them and thought about mounting some in the same place, but I go 6 months or so without the top. Looks great for people who rarely go topless.
Potluck99
Potluck99
Las Vegas
just two more disconnects to go along with the rear washer and plug.
kodiakisland
Arkansas
Yeah. I just didn’t want to have a different setup with top off. I think that’s an ideal location though.
Potluck99
Potluck99
Las Vegas
makes sense. I don’t take the top off on dusty trails (live in the desert) when I’d be using the chase lights.
only downside is if the top was off and I wanted to have a disco party I’d be out of luck 😂
Ben
Baltimore, MD
2023 Bronco Raptor
Very nice. Which lights did you get?
kodiakisland
Arkansas
I’m rethinking all the dusty top off I’ve been doing. When I pulled my interior panels out there was a heavy coating of dirt everywhere.
Potluck99
Potluck99
Las Vegas
Yep. The worst. Same with sand dunes. I keep forgetting to roll my windows up and inevitably I get sand everywhere.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Those turned out great!
Topher
Christopher
Pasadena, CA
2023 4 door Outer Banks, Cactus Grey, MIC, LUX
Can you explain a little more about how you mounted them? Did you just screw it onto the plastic covers? Do they just pop off? I want to try doing something similar but don't want to crack the cover getting it off. :)
Jakob1972
Everglades
Steven
Spring Branch, TX
2025 Trax 2RS, 2022 Camaro, 2022 Silverado, 2004 Fummins F250, 2008 Chevy Cobalt
Everglades
Sorry this might be a little late. but the covers pop off you have to push them up they have little hooks that hold on to the hinge pin. if you open the glass you can see them. it helped if i pushed them up with the glass open then had to close the glass to get them off. I am using the Nilight RGB set but they look identical to the OPs lights I had to use shorter screws then what came in the lights, to mount them dilled a hole for the cable and two holes for the screws mounted them with some RTV, I just need to mount the control box and wire them up.
I was going to mount the second pair on the sport bar for when I am rolling top off and need the lights.
