DIY Bronco Raptor 2-Door ?
Dmorty217
Derek
Venice FL
Camery
I just installed a Raptor grille on my black diamond today. Very simple and bolted right up. I assume everything else would also work the same way. Going to get the Raptor front fenders too
Ford Bronco DIY Bronco Raptor 2-Door ? 7ED236D2-5D2F-4EB9-93B4-D0DD3F0CD0BE
Oldhippie
Barry
Santa Cruz, Calif.
BMW X1, ā€˜1928 model A, ā€œ23 Bronco
I’m hoping the ā€œoatesā€ will be a ā€œhalf raptorā€...
Skydoc
Ethan
2018 F350 , LS3 V8 Jeep Wrangler jku
Hello everyone:
So I love the Bronco Raptor but wish it was available in a 2 door. I am going for looks over performance right now. Let's say you get a 2.7L Sasquatch (doesn't matter what trim) and add the following:
-Bronco Raptor or Ranger Raptor rims
-Bronco Raptor grille
-Bronco Raptor Headlights and Taillights
-Maybe a 2.7L tune?
Now for the big question. Would Bronco Raptor Suspension pieces, hood, bumper and fender flares bolt right up to a regular a Bronco?
Thanks!
2022-ford-bronco-raptor-two-door-rendering-is-nothing-more-than-wishful-thinking-180418_1.jpg
Edit: Nevermind a shorter wheelbase won't hurt things
I really want the upgraded he steering rack out of all the raptor parts…oh and the dash they should have put in the regular broncos from the start😔
2020FordRaptor
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
I'll be honest, I love that grille except for one minor detail. I wish the letters weren't as spaced out. Otherwise than that I love it and your bumper!
2020FordRaptor
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Well the HOSS 3.0 has the steering rack from the Bronco Raptor.
Skydoc
Ethan
You are correct but can’t get in badlands I don’t believe for some odd reason and I already own my badsquatch. I would just like to purchase the rack from ford and install myself but I don’t see a chance of them selling for a few years at best
2020FordRaptor
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Yah I'm wondering when they'll start selling it as an accessory.
Triceratops
10 speed Huffy
That is definitely a knock off grill. Here is an OEM on my two-door:
Ford Bronco DIY Bronco Raptor 2-Door ? 9EB44AF9-D1C4-4F93-A2B4-9ABABFA221AB
Dmorty217
Derek
Venice FL
Camery
Yep drop shipped from cali by a Chinese company but I haven’t been able to find the OEM anywhere.
MadMan4BamaNATL
Ray
Atlanta
There was a thread a couple weeks back on this topic. There is an issue with coding anything but the OEM rack with non-matching VINs. Theretically, this is to prevent theft.
Basically, a guy did the install; which wasn’t that bad, but couldn’t get the hook ups to work properly until there is a hack or workaround. Not sure he has that sorted just yet.
2020FordRaptor
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
BigMeatsBronco
Allan
2021 FE 2 door
Hello everyone:
-Maybe a 2.7L tune?
Thanks!
No, the suspension pieces off a Braptor do NOT bolt right up, unfortunately there are numerous differences. the differences are... lug bolt patterns, UCA mounts, tie rod taper, UCA and LCA ball joint tapers, knuckles, unit bearings, ABS sensors, CV joints, and IWE, of course the shock towers and UCA angle are also different. . all of these need a work around to make it function.
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
To get partially there, rumour has it Ranger Raptor parts might fit the Bronco platform, giving you extra width and extra wheel travel. UCA, LCA, axles, knuckles, new shocks will all be needed.
I started piecing together part numbers, but have since lost interest as realistically I have yet to push my Bronco past the point of it's current usability.
Here is the list I put together so far. I have *NOT* verified fitment or validated front shock details. Use at your own discretion but if you're looking for a jumping off point, this could be worth something to someone. This list is also NOT all-encompassing or validated for correctness.
If someone has performed this work, however, I'd love to hear about it.
Ranger Raptor Parts List
Part NoDescriptionQuantityPrice/unit ($CAD)Total Price ($CAD)
MB3Z-3K186-EKnuckle Side 11427427
MB3Z-3K185-EKnuckle Side 21412412
MB3Z-3085-DUCA Side 11122122
MB3Z-3084-DUCA Side 21123123
MB3Z-3078-CLCA Side 11386386
MB3Z-3079-CLCA Side 21376376
MB3Z-3A427-JLeft front axle1475475
MB3Z-3A428-MRight front axle1482482
MB3Z-18125-BULeft front shock115051505
MB3Z-18125-BTRight front shock115051505
MB3Z-18089-HLeft shock protect1172172
MB3Z-18089-JRight shock protect1172172
PB3Z-5K570-BBump Stops271142
MB3Z-5560-DZSprings2198396
MB3Z-18K050-AShock Mount cover22142
MB3Z-5415-CInsulator254108
MB3Z-18124-BMRear shock2163326
MB3Z-5310-BKRear spring2183366
MB3Z-18A099-CStrut Mount2100200
BigMeatsBronco
Allan
2021 FE 2 door
I can't verify that all the part numbers are exactly correct however your assumptions are absolutely correct! I HAVE VERIFIED all of the parts will bolt right on from the ranger Raptor although you would also need the brake calipers and rotors and caliper brackets that's because the Bronco ones don't fit on the RR knuckle ( you could also just use Bronco Knuckle) and finally a sway bar link for each side.
