Ditch lights
Mdemieville
mark
2011 Lincoln MKZ hybrid
Haven't seen this question yet but maybe I missed it. It appears that on the mirror arms an accessory can be mounted. I was thinking of putting ditch lights there. Does anyone else hope they included a wire run under that cover? Also it would be nice if someone came out with a light that has a base/mount that simulates the cover so there isn't just an opening there. What are your guys thoughts?
Zinn
Minnesota
2016 Mustang GT, 2020 Ranger Lariat
I thought the High package has this already, puddle lamps and spotlights. Maybe this is a different question entirely but I wonder if it’s possible to swap the High package mirror and light assembly onto a lower trim, or if the wiring simply won’t allow it.
Mdemieville
Mdemieville
mark
Puddle lamps go under the mirror to illuminate the ground at night for when you are walking up to the truck. My lincoln has them and they are nice. Not sure about the spotlamps you referenced
BroncoKong Jr.
Andrew
I think the light mount would go on top, using the included bolts. Wire would run into the hood right next to where the mirror... thing is.
attworth
Tony
2000 Land Rover D2
These lamps should be like on the F150. They’re not quite big/bright enough to light up the ditch on back roads at night. They’re nice for camping, loading up gear or doing some light work at night.
Ditch lights like OP is talking about are usually some high powered LEDs pointed towards the ditch to keep you out of it, or to avoid hitting critters.
AK SNO RIDER
Ty
Alaska
They also shut off and cannot be used above like, 6 mph.
tomknight
Tom
North Georgia
Jeep (3), Fiat Spider, MB ML
Like these?
Ford Bronco Ditch lights n
tomknight
Tom
North Georgia
These are mounted under the hood hinge via a bracket. On the Liberty, there is a grommet in the fire wall that let me push the wires through, and install a switch inside.
Took a little field engineering to make sure the hood doesn't hit them when it closes or opens, but that location has worked out well.
Mdemieville
Mdemieville
mark
The bronco has a spot on the mirror arm for them. Which i think will work out well, as long as there is a base for the lights that will fill the void
Mdemieville
Mdemieville
mark
What void?
When you remove the cover on the mirror arm and install a bracket for the light it looks like due to the shape of the cover the brackets will leave an area that is unfinished and would look funny in my opinion. Ill see if I can find a pic of what I'm talking about
Mdemieville
Mdemieville
mark
having a hard time finding a pic but I know I saw it in one of the videos when they are talking about the bronco bolts that when removed make way for accessories
Bronc-O
Phoenix
2021 Lincoln Aviator
There's probably a wire there if you choose the upfitter switch option.
Bronc-O
Phoenix
Ford Bronco Ditch lights build
