Disabling TPMS Sensors
chtucker
Kirkland, WA
FJ Cruiser
These Methods are single valve stem but the problem is the mount itself in inset to the whee so it could potentially work with a spacer.
Guess I will find out on my TR wheels in a few days if I have the same problem..
did you buy new sensors? If so where and how much?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I've turned off TMPS on all the modern Fords I've had. Most of them it's been a simple click in Forscan. Unfortunately without a Bronco I haven't seen "under the hood" yet.
ModifyMike
ModifyMike
Ford F450
Dealer is throwing the wheels on for me and already had the factory sensors in stock.
ModifyMike
ModifyMike
Ford F450
I asked my dealer and he said that the newer Ford’s are different, I disabled them on my 2017 Super Duty.
Tricky Dick
Dick
PNW
Of course they would be, can't have anything easy right?
I wonder if you could go back to a band sensor?
mpeugeot
A small 315MHz transmitter spouting the right "data" would get the job done.
Jfman
jean
Canada
Accord
Bumping old thread. Has this been figured out yet?
I would like to know how to disable when running winter wheels tire combo w/o tpms
mpeugeot
just use Forscan
Trickster
Trick
Tucson, AZ
22’ Badsquatch, Lux, Cactus Gray, 1991 5.7 bronco
mpeugeot
Awesome do you know the sequence for Forscan? I’ve been all over these threads and have not found it.
I will look it up when I get home.
mpeugeot
Trickster
Trick
Tucson, AZ
BTW, I think that it's under the BCM section.
Hey, MPeugeot
did you happen to find the sequence I get that it’s under the body control module section but would like to fully understand what to change it to?
mpeugeot
Hey, MPeugeot
I broke out my laptop to look and the battery was dead, so naturally, I couldn't check.
I am nearly dead positive that it's under BCM and it's a simple pull down menu, you don't have to enter in digits.
