Diode Dynamics SSC1 Ditch Light Hack
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
OK. So, I am pretty ignorant on lighting. Your lights when off, appear to be standard white light. In the first "On" photo, they appear Amber. Then they again appear to be white in the final photo. I don't understand how the lights work. Are they amber? Are there two "On" settings, Amber & White? Is this unique to the DD Lights?
Almost all of the DD lights have an "auxiliary backlight" feature, which is the amber you are seeing. It's a separate wire and can be controlled via a separate switch (or running light tap). They also offer red, blue, and white as backlight colors. The white is the main light. When the lights are off, you can't see anything other than a clearish white lens.
BulletTheBronco
BulletTheBronco
Hunter
Oklahoma
2023 Bronco
The backlight essentially lets you use them as a driving/marker light as well when not offroad.
RAC-Wildtrak
RAC
2023 Wildtrak
Thanks for the education!
