Installed Diode Dynamics SS3 ditch light kit today...
Hal deane
KnightShade
St. Louis
2024 Ford Bronco - Sasquatch 2.7
No lights. no backlight or main with switch…which is why i tried a new ground. Well I can disconnect backlight and see if main will work..
yeah I bought the harness to do the backlight because I would not attempt to ‘patch’ into the headlight, and it is working on my fog lights. Didn’t want it on a switch.
No lights. no backlight or main with switch…which is why i tried a new ground. Well I can disconnect and see if main will work.. yeah I bought the harness to do that because I would not attempt to ‘patch’ into the headlight, and it is working on my fog lights.
Do the lights work if you go straight to the battery?
Hal deane
KnightShade
St. Louis
No, no lights at all.
i bought the harness for the headlight because I wasn’t going to bust into that, and it works for other lights.
i can disconnect the backlights to see what that does, nut seems so odd to not work.
Hal deane
KnightShade
St. Louis
they worked when on the relay so I would say yes to whether they work off the battery.
