4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
The new Diode Dynamics Chase Light is Here!
Built to upgrade rear visibility, utility, and style in one compact universal setup.
Get a programmable amber chase light, high-power brake light, and white reverse light in a clean package made for trucks, UTVs, overland rigs, and more.
Mount it almost anywhere, wire it your way, and change patterns in seconds with SmartTap® programming using the included magnet tool.
Choose from 20 chase patterns for the trail, camp, or jobsite, then dial in your brake mode with solid output, triple-flash SafetyStrobe, or off-road pulse.
Available as a 10" Light Bar Here: https://www.4x4truckleds.com/diode-dynamics-ss10-10-led-chase-light/
We also have a Spare Tire kit available for those who want a "plug & play" installation (the only real wiring you have to do is connect the upfitter pass-through behind your rear seat to the cable we provide): https://www.4x4truckleds.com/diode-dynamics-ss10-chase-light-reverse-light-kit-for-2021-ford-bronco/
Ford Bronco Diode Dynamics Chase Light Is Here 1776962781722-q0
Ford Bronco Diode Dynamics Chase Light Is Here 1776962788135-6z
Ford Bronco Diode Dynamics Chase Light Is Here 1776962797024-jf
Ford Bronco Diode Dynamics Chase Light Is Here 1776962810392-5
Ford Bronco Diode Dynamics Chase Light Is Here Bronco2
Ford Bronco Diode Dynamics Chase Light Is Here Bronco4
Ford Bronco Diode Dynamics Chase Light Is Here Bronco3
Happen to be working on a bracket and harness to replace the CHMSL to go with this?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Sign me up
Well it's not as simple as that. The factory one is molded in so it's not going to be a direct replacement BUT we have a current "kit" available that puts it in the spare tire area at least.
jtgensler
Jamison
Clarion, PA
2022 Bronco
after how shitty my @Turn Offroad one looks because their finish is junk & the chinese lights are so cheap, I'm gonna order one of these & figure out how to mount it on their bracket.
I have diode for all my other lights, so I might as well get this one too
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Grab one from us. We're actually going to be releasing a kit in a few weeks for the spare tire. It'll do brake/reverse/chase all with a plug and play harness. But for now, you can grab the SS10 chase bar from us
jtgensler
Jamison
Clarion, PA
2022 Bronco
I'm gonna order one when I get home from work.
Is it really already out of stock? that was quick lol.
I think I can make my current harness & mount work without too much difficulty.
Mikerider
Washington
Raptor, Ranger, Mustang, Focus, Explorer
Got a wiring digram? how many trigger wires are there to control the various modes? looks like the pig tail is only 3 wire which limits the modes a fair bit.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
It's a pre-order item. It was announced today but won't ship for a few weeks, so nobody has stock right now. It's new.
jtgensler
Jamison
Clarion, PA
2022 Bronco
Gotcha. I thought I'd heard about it a while ago, so when you said "it's here" I thought you had them already.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
3 trigger wires, 4 wires total
1 for REVERSE
1 for BRAKE
1 for CHASE
1 for GROUND
And you can change the chase functions via the included magnetic "wand" (basically a magnet that triggers an internal reed switch). So you can cycle through the patterns that way and it remembers your last pattern.
So you can't use it as a turn signal.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
We're not allowed to talk about new products until the official RELEASE date, which is today. Sorry. So you may have heard about it and seen some videos from SEMA but dealers were not allowed to disclose much else other then what the public saw, until TODAY.
Mikerider
Washington
1 for REVERSE
1 for BRAKE
1 for CHASE
1 for GROUND
Bummer, mostly I want Chase and Strobe function via a switch not having to get out of the car and change flash patterns. Will stick with my tried and true serial controlled multi color strobes. they are less expensive too.
jtgensler
Jamison
Clarion, PA
2022 Bronco
Ordered.
Will be glad to remove the only non Diode Dynamics light from my rig.
