4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Well if like to get a light and a bracket. I guess I'll be waiting until you guys post something?
when our brackets arrive Thursday we will
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Brackets are now available on our site. You can buy JUST the bracket or you can buy the bracket + SS10 Chase Light and receive a small discount as part of the bundle
Harnesses we're still working on
SS10 Chase Light: https://www.4x4truckleds.com/diode-dynamics-ss10-10-led-chase-light/
Mounting Bracket: https://www.4x4truckleds.com/kr-off-road-u-bar-mounting-bracket-for-diode-dynamics-ss10-chase-light/
Spare Tire Mounts:
Ford Bronco Diode Dynamics Chase Light Is Here 10-3000-1
Ford Bronco Diode Dynamics Chase Light Is Here 10-3000-4
Ford Bronco Diode Dynamics Chase Light Is Here 10-3000-7
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Are the harnesses long enough that if I wanted to mount it roughly where the existing CHMSL is, if, you know, I made a bracket that would fit the light bracket here and just tossed the spare tire mount stuff. Would they reach with a decent sized tire mounted on the back - or are they pretty much cut to exactly fit that spare tire mount?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Well the harness in our kit goes to the spare tire. It might be long enough to keep going straight up about a foot but if not there is also a 3m extension cable included as well.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
When needing to remove the spare tire, it appears you’d need to remove the light first?
Yes and No.
Yes you need to disconnect the light (easy). No you don't need to remove it from the mounting bracket. Yes you do need to remove the spare tire mounting bracket (which is what holds your spare tire on).
The mounting bracket uses 2 of the 3 bolts that hold the spare on.
Not a big thing. I've done it before with a reverse kit to access my spare.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
I like this a lot, but it goes exactly where my license plate is mounted now. Not sure it would work.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Finally had the chance to order today. Order #46215
Great. Where do you plan to mount it? As I only saw the light ordered. No spare tire bracket or wiring harness
Ratfink33
Chicagoland
2024 Bronco Heritage Limited 2 door
I thought I clicked the one that gives me your bracket? And I have a set of chase light brackets that mount to the spare tire bracket that extend above the spare that I plan on mounting the light to. And I had the DD chase lights previously. So I already have the harness that plugs in between the taillights.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Gotcha. Yeah our bracket is a U-Bracket which you'll need in addition to a spare tire bracket.
What DD chase lights did you have previously? These is a different product/different wiring then any other product DD has released.
Ratfink33
Chicagoland
I know I'm going to be doing some wiring. I mean it's only a 4 way plug. Most likely ground, brake, white, and chase. I have the power from the reverse and brake light coming off the DD harness previously that plugs into the tail light harness. And the switched power from the aux switches. Most likely I'll send a second switched source to the rear to control the chase lights. Biggest thing I feel I'll be worried about is that crossover between the 2 towers from my slinky fab chase light brackets. I don't think the 10" will bridge side to side. So guess I'll be firing up the powder coat machine after I make a flat piece of metal to attach the light bracket to.
