Developing a HATE for my Load Range E Tires
dankeller13
dankeller13
Dan
Souderton, PA
Do you experience any rub with the tires? I am planning to put the goodyear wranglers that come on the sasquatch on my badlands and was considering the leveling kit. I know a lot of people complain about picking up gravel but they seem like the best on road tires with some off road capabilities
No rubbing, crash bars are removed. Wheels are a zero offset if I remember corrrectly.
Wickedbronco
Jon
Chicago
Timely thread… I am pretty set on the Kenda Klever R/T tires but can’t decide if I want to go with 35-10.5 or 35-12.5. the 10.5 are D rated and 12’s are E rated. I like the look of tge 12.5’s but know ride quality and gas mileage might suffer. any thoughts?
ByrdDogX
Jason
Olive Branch, MS
22 Ford Bronco
I ran my Jeep at 28psi on E tires. Never had problem with wear and ride was much better than recommended 36-40.
RubyRedGT
Greg
Pittsboro, NC
21 Bronco. Sold the 1968 and 2015 mustang GTs
I have non-SAS Badlands with E-rated Toyo Open Country AT3. I run 34 psi front and 32 psi rear and haven’t noticed any significant roughness in the ride or difference from the factory tires.
HoosierDaddy
__ Eric
I have been running 40 psi. I wasn't comfortable any less. 32psi? Seems really low but at this point, it is give it a shot or shell out $1500 for new rubber...
40 psi, Holy Hell that's high.
I haven't read all the replies yet, but there are charts/calculators for this. They cross reference what the door sticker says the tires load rating/size/pressure should be vs what your new tires are.
Even at that, my Toyo 35 x 11.5-17 Load C chart out at 32 PSI , yet that was still pretty stiff, dropping to 30 helped. I've tried 28, it rode much nicer, but that low of pressure sketches me out on the hiway.
TallDude
North Seattle
I went with the 10.5 because they’re D’s, also I liked the look of them. For my kinda trails these are perfect.
mcinfantry
Lee
Louisiana
Badlands 2 door
What I use
TallDude
North Seattle
BroncoAZ
Mitch
A thread about someone not satisfied with E rated tires on a Bronco?
Ford Bronco Developing a HATE for my Load Range E Tires 718BC42F-A93E-4155-B208-267451CEA4F5
Silence
SD
2022 Bronco
I went from 40 PSI to 30 PSI in my Ridge Grappler E rated and it was night and day difference. Still rated at over 1500lbs per tires load - im good.
MLRey
Lancaster, CA
21 Ford Ranger Lariat FX4, 18 Subaru Outback
E rated tires are overkill for the Bronco. I had them on my Ram 2500 and ran them at 50 psi when not towing and 75 psi when loaded up and pulling an 8K lb trailer. Not too bad on that truck but the E rating is far more load capacity than you could ever need for the Bronco.
CPL_Rabbit
Ozarks
Minivan
E rated tires are overkill for the Bronco. I had them on my Ram 2500 and ran them at 50 psi with when not towing and 75 psi when loaded up and pulling an 8K lb trailer. Not too bad on that truck but the E rating is far more load capacity than you could ever need for the Bronco.
I was planning to go the pizza-cutter route with 255/85-16 33s. This thread has me second guessing since the only options are E load.
Black_Stallion13
Cincinnati
Tacoma
Well, it's simple: bigger, heavier, more aggressive tires = worse road performance. Personally, I'm loving the 25+ mpg/handling on the freeway with my stock 32s. May upsize to standard load, mild tread 33s when the stocks go bad but nothing more if even that. Been there done that not worth it if you aren't hardcore wheeling.
