dead upfitter wire
74broncosport
scott
clarinda
24 badlands 22 willdtrak
working on installing my new 4wp bumper and lights. I used the provided wire that comes out in the rear area near the sub. connecting it to the wire behind the glove box than to the #2 upfitter and after i finished up nothing worked. tracked it to the section between the glove box and the sub. no big deal just ran another wire but kinda surprised to hit a broken wire . Seems like a good time throw some fancy speakers at it now that its all tore apart!
Deadpool392
New Bern, NC
2025 Marsh Gray Bronco Raptor, 2020 Gator JTR (retired)
You found the broken spot in the wire? When I was wiring up my rear light, at first I wired up the wrong wire (the A pillar wire) due to the two wires being too similar in color. One was orange and white, and the other orange and gray. once I figured out the color issue, and traced the rear wire all the way up the passenger side, I found it was tucked up and the end taped into a loom which made it hard to find.
helifino16
Ron
Mount Sinai, NY (Long Island)
ran a new one thru the door sill ..problem solved.
Probably a better choice since that wire ends short of the rear of the vehicle (I believe it ends right behind the B pillar).
