Dash mount broke, anyone else encounter this?
Jimmyjamesh925
James
Los Angeles
2021 ford bronco badlands 4dr
I had a phone mount that goes into the center dash part behind the emergency lights/lockers button. One day I adjusted the angle of my mount and it plopped off. I can’t get a good look inside to see if something broke or fell into the little well but I’m aiming that’s what happened because the mount is no longer attached to this part, lol. Anyone else encounter this or have ideas to remedy?
Ford Bronco Dash mount broke, anyone else encounter this? IMG_6782
Ford Bronco Dash mount broke, anyone else encounter this? IMG_6784
Ford Bronco Dash mount broke, anyone else encounter this? IMG_6788
TY everyone
adam1991
VW GTI (2)
The assembly is accessory ready--which means it simply unscrews and comes right off. Might be fixable, is easily replaceable.
PowerBronco
Steven
23 Bronco Badlands, 07 FJ Cruiser, 04 WRX STI
To me it looks like the nut backed off of the mount. You should be able to pull the whole mounting assembly via the 2 screws and put the nut back on.
HotdogThud
mk6 gti, '21 MoarDoor
What he said, but be prepared to go in with a long magnet on a stick to get that loose nut, it wants to fall into awful places.
RNC
Roger
Ohio
2022 Ford Bronco
Replace with the Mabett dashboard charging port.
Tricky Mike
21 Bronco
It's happened to a few people on here. It's a very light duty mount.
Is the current revision pretty good? I got a version 1 and it's awful, intermittent power and very low wattage when it does work.
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
I have revision of it and it has been sitting on my workbench for months as I procrastinate removing my 67D device rail and any other bits i need to get out of the way to install it. I'm just not filming shit anymore.
The ports that it pulls power from barely provide more than 12W of charging, so I'm thinking it's usage will be pretty darn limited. I really need USB-C PD ports more than anything. Being stuck at 12W sucks.
RNC
Roger
Ohio
2022 Ford Bronco
I don't know anything about revisions, or versions. I bought mine from that youtube Buttercup girl. Easy install, works as a data port. Good performance.
huey
kevin
Ontario & Kentucky
