michigan-sasquatch
Bronco sasquatch
Also note that’s the Bronco raptor fan installed as well, since I have a bunch of stuff taken apart, might as well fool with it at the same time
Is there a big benefit for installing the braptor fan?
Gluestick
Josh
Nashville
instagram.com
No, since it’s electronically controlled, even with higher power (1000w), I doubt it will make a noticeable difference.
Gluestick
Josh
Nashville
instagram.com
Gluestick
Josh
Nashville
instagram.com
Interesting. Both my original (23MY) and the Raptor fan are the same
Ducati1098
Ducati1098
Gluestick
Josh
Nashville
instagram.com
Ah very helpful!
Gluestick
Josh
Nashville
instagram.com
Alright: between work and heavy thunderstorms, I’ve made only a little progress. It seems that the ADD Adaptive Cruise Control bracket with spacers to lift it up slightly, and a lower bolt either removed or a low profile head put in backwards, you might have enough clearance.
Will update as I put things back together, but some quick pics:
Ford Bronco CVF High Mount Intercooler install and testing IMG_6189
Ford Bronco CVF High Mount Intercooler install and testing IMG_6191
Ford Bronco CVF High Mount Intercooler install and testing IMG_6194
Q1svt
Sunny & Warm SoCal
2025 Badlands, Sas-sy Manual 2dr, # of fords
… Well when it’s on it’ll pull harder at each speed. But yes still need better mapping to turn it on more often.
Got a couple friendly inquiries how OEM has Braptor set and what/where the coding is.
… just question is the Fans the same… or the Fan shroud?
Gluestick
Josh
Nashville
instagram.com
Shroud shape.
Gluestick
Josh
Nashville
instagram.com
Shroud hole problem solved — thanks for the tip @Ducati1098!
Ford Bronco CVF High Mount Intercooler install and testing IMG_6575
Canyon Coolers
Jason
Flagstaff
canyoncoolers.com
73 Bronco, Dodge 2500, Sprinter Van
While I love the size and added space, how much airflow to the radiator is being lost? Have you tracked coolant temps?
I have the Mishi Moto one and my coolant temps stay fine, I do get higher than I prefer oil temps at 85 mph on 37's. I also live at 7,000' with less dense air and mildly tuned.
