James Cole
MX
Badlands Sasquatch (hopefully)
Wow!
how did you get a clean signal out of the OEM system?
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Love it!! :love:
I wonder where the second amp/DSP is hidden?? Didn't see that in any of the photos. (EDIT— Just kidding, both amps are there. Looks like driver side has the speaker amp and passenger side as the subwoofer amp.)
I also didn't see how the doors are wired—if he used the extra pins on the door connector that would be awesome. That's an idea I've toyed around with personally, but I was at my self-imposed budget limit for my upgrade so decided to table the idea for later. (I also am not sure I'm willing to lose the door storage.)
All-in-all this is definitely the way to do it if you really value audio quality. The real question is if you are willing to lose the storage with the subwoofer and speakers in the door/cargo area, and the "washability" by sticking electronics under the seat.
Wow!
It's just a simple Forscan change. He could have also cleaned it up with a DSP assuming he installed a DSP. I would assume he did, but it wasn't photographed.
JP Fabrication
LA, CA
Bronco, VW R32, OBS Chevy Crewcab
Looks sweet!!! How did you wire up these door speakers? Were you able to tap into the factory harness that disconnects when you remove the doors or are they now hardwired and the doors unable to be removed?
I did not tap into the factory connector. There is a factory grommet behind the rubber door jam "filler" trim I used. then went through the factory wire harness door grommet. There is no connector added as these doors will never come off. A deutch connector can added for door removal.
There is a guy I follow on IG and YT that said he came up with a way to run the wires. I will post a link when he releases the video
ToddReynolds
Todd
Plant City, FL
2014 Raptor, 2023 Badlands 2 Door
Awesome thank you!!!
HOSSMAN
HOSS
Hill Country, TX.
2023 Badlands, 2022 BMW X3 M-SPORT
Very nice!!! Having my system put in as we speak. Are you running JL 10's? W-1's or W-3's? They are building me a down-firing JL 10's box behind my 900/5 JL amp.
KABQ
Aaron
Albuquerque, NM
I'm curious about this as well. I'd like to know a part number for the pins to go through the factory connector
Draughon
Daylon
Dallas
BMW 4-Series
Great work! I wish you lived in my neighborhood. ;-)
JP Fabrication
LA, CA
10 TW3's. My first setup was a single 10TW3 on 550watts from a 5Ch Audison. Now I have 2 10TW3's on 1000watts. These are my favorite subs
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
Wow! Just, wow! This is very cleanly done. Major props to you
35tires
'23 Bronco, '21 4Runner
Maybe I'm silly but where did you mount those crossovers?
I have focal slatefibers and tried to put them in the foot wells but I think I get some sort of harmonic feedback because I'll catch a high pitch whine from the speakers at higher speeds.
JP Fabrication
LA, CA
The 3-way Crossovers are under the drivers seat next to the 4ch amp. The door speakers are active
5GENIDN
Joe
Idaho
Let me guess, NOT your first rodeo.... Well done. You got skills!
Merc4x4
steve
NJ
IMG_1905 by Jon Polo, on Flickr
IMG_1904 by Jon Polo, on Flickr
Can you elaborate a bit on the parts used in your firewall pass through? Is that piece glued in place?
thanks.
Superb install. Outstanding craftsmanship.
