Crash Bar Removal: Torque nut stripped
Sandy56
Tennessee
2022 Outer Banks Sasquatch
You should be using a TP40, which is a torx plus. They’re close, but they are different and using the wrong once can cause issues like you ran into.
I really don’t understand Ford’s logic with two extremely similar hardware
Sandy56
Tennessee
I was highly disappointed when that thread got nuked. Commies😂
Richtor
Richtor
Sonoma County
20 Tremor 7.3, 21 Badlands Sasquatch Stick(order)
This video said T40. They did not come out as easy as they did in this video. Haha.
zoober
Robert
Rossville, Tn
‘24 OBX SAS LUX
Try the medical world where every device manufacturer has a different bone screw hexalobe driver because ”muh patents”
zoober
Robert
Rossville, Tn
‘24 OBX SAS LUX
Put it in the rescue med pack. Never know when you might need to screw a finger or toe back on..
Q1svt
Sunny & Warm SoCal
2025 Badlands, Sas-sy Manual 2dr, # of fords
Ducati1098
thanks... they have an interesting cutting style tip...
Do you give them a tap to seat them past any of the damaged metal?
Yep, normally just tap them in and they surprisingly grip very very well, even with really rounded out bolts.
Blackcat
South Carolina
2022 FORD BRONCO BASE 2 DOOR M/T
I’m guessing Torx Plus can be more accurate when fastening to a particular torque. I personally sell a pile of regular Torx bits, but they’re used on trailer deck repair, where you just tighten the damn thing!
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
You and me both 🤷‍♂️
It’s not just Ford though. Torx plus is becoming very popular
OOoooo I know this one!!! I knew this expensive engineering degree would be handy some day.
For machinery, electronics, etc. Torx Plus is objectively better. It has an awesome contact angle with the driver, It can achieve higher torque rating, less contact stress, less cam-out problems, near-perfect force transfer, longer lasting in the face of corrosion, etc. etc. All why manufactures are moving to it.
The obvious problem is Torx is much more common in construction, and unlike with machinery they have no incentive to switch. If they end up stripping a head on... say... a deck screw they'll probably just shrug, grab another one from their tool pouch, and drive another one in right next to the bad one. Sucks for us because at your typical hardware store you'll find Torx everywhere but struggle to find Torx Plus.
