Crash bar opinons
Severum17
2024 Badlands Bronco
I see a couple of bolts on the crash bar ends. Why are they there? I also see crash bar videos where the bars are removed. Tire clearance I see. What other purpose do the bars have?
CitrusBronco
Everglades
Citrus county, FL
Everglades
What I believe you’re seeing is the crash bar mounts, the bolts would hold the crash bar extension which is not included with a SAS model.
The mounts are what people cut off to fit larger tires like 37” and above.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
What you described is exactly correct. They’re crash bars.
Up to ≈33” tires, the crash bars are installed from the factory. They provide an extra protection from (primarily) front-overlap impact crashes.
For the Sasquatch package (≈35” tires), those crash bars are removed and not included with the vehicle due to tire clearance.
crenca
Southern New Mexico
I don't know why those two bolts are there from the factory. If I remember correctly they even have loctite on them. They are too short to be part of an install of an aftermarket crash bar install (such as the one I went with: https://www.boss4x4.com/product-p/4wp8-62213.htm ), and you need 4 of them anyways...I ended up at the dealer part counter purchasing 4 OEM bolts to get mine installed.
Bobio
Bobby
United States
2024 Bad lands
Does that after market fit perfectly with the sas 35’s? Thx
crenca
Southern New Mexico
Yes. On road & off road (moderate, level 5 trails usually though with boulders/shelf's that pretty much max out stock SAS clearance/articulation) no rubbing.
Bobio
Bobby
United States
2024 Bad lands
Thanks
