- Brian
- Sep 14, 2023
- 64
- 8,810
- 15,727
- Central CA
- '23 BB 4dr 7MT, '22 BSport OBX, '87 B-II XL
- Big Bend
So, the way these newer headlamp assemblies work. They are digital. They get power all the time, and use CAN bus signals to tell the headlamp what to do.i have not tryed it yet… but I don’t understand why we can’t tap into the low or high beam light line to operate other lights with a relay.
So, yeah, there's power there in the harness and at the fuse box, but it will be hot all the time, regardless of if the high beam is on or not. It even says so on your wiring diagrams - Note (2) - Continuous 12V.
So, if you want to see if the high beams are on, there are a few ways:
The stock setting on the Bronco is that if the high beams come on, the factory fog lights come off. So you can see if the factory fog lamps are off and infer that the high beams are probably on. That doesn't work if you run Bambi lights though, and it isn't foolproof - like when your headlamps are all the way off, and so are your fogs.
You can tap into the CAN bus, and see the high beam signal going to the headlamp. That's what the XBB unit does.
You can crack open the headlamp assembly and tap into the wire going directly to the high beam LED. I haven't seen anyone do this yet, but it's possible if you wanted to figure it out.
You can use a hall effect current sensor to see that current is flowing through the high beam circuit, and that will tell you that the high beams are pulling power and infer that they are running. I haven't seen anyone do this yet either, but again, it's possible if you wanted to figure it out.
