Component speaker adapters for dash....
Tombky
Thomas
2Conline!
2022 Bronco
I saw a link in a post where someone was 3D printing speaker adapters for dash.. could someone share the link
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
So are you going with a three way install, and running a second wiring run to the dash? (I had thought about this.)
Tombky
Thomas
2Conline!
2022 Bronco
Having professionally installed... They wanted $350 to Fab a plate.. these are $25 for set
BroncoAZ
Mitch
This is another option. They fab plates for the tweeters and the 6.5”.
https://www.mtiacoustics.net/ford.html#!/Installation-Accessories/c/127527301
I want to go components up front rather than the 6.5” and 4”, I’ll be using the Kicker Key 200.4. I’m having some analysis paralysis choosing speakers. I always ran Boston Acoustics in everything through 2012 or so, but I haven’t built a sound system since then. I’m looking at something in the $300-400 range sonde I’m only buying one pair. I prefer a soft tweeter with a smoother sound to an aluminum tweeter. The JL Audio and the Kicker below are my current top two. The kicker 6.75” apparently can get down to 35 Hz, the JL is probably higher quality overall. I don’t know anything about Memphis or Morel. The Morel does have the cpas and coils built on to the speakers rather than separate crossovers, also 94dB sensitivity.
https://www.crutchfield.com/p_136C2650/JL-Audio-C2650.html?tp=106
https://www.crutchfield.com/p_20647KSS67/Kicker-47KSS6704.html?tp=106
Tombky
Thomas
2Conline!
2022 Bronco
My set up:
Alpine Tough Power Pack 300X1 Factory subwoofer enclosure.
K2 Series 2-Way Component 6.5in
JL XD 4-Channel Amplifier (100x4)
Focal ACX 100
Dads_bronze_bronco
My set up:
Focal ACX 100
Interested in how this works for you and whether you mids are harder to discern because they are down low in the kick.
GreyCactus
Southern California
