Check engine light on
Way2Fast
Sam
Santa Maria, CA
First day of 3k mile road trip to Utah, Colorado and Idaho. My check engine light came on. I stopped and had an OBDII reading.
Water, oil and transmission temps are normal.
Can this wait until I get home in 4 weeks
Ford Bronco Check engine light on 110640
TomC
Tom
28712 or 34986
21 Bronco /25 F150
hope this helps - AI.
Diagnostic trouble code (DTC) P0078 on your Ford Bronco means "Exhaust Valve Control Solenoid Circuit (Bank 1)." This indicates the Powertrain Control Module (PCM) has found an electrical circuit or voltage problem with the variable valve timing (VVT) solenoid that controls the exhaust valves on the side of the engine designated as Bank 1.
Common Symptoms
    • Check engine light is on
    • Rough idle or engine shaking
    • Poor acceleration or hesitation
    • Lower gas mileage
    • Engine stalling in some cases
Main Causes
    • Faulty or stuck exhaust VVT solenoid
    • Damaged, loose, or corroded wiring and connectors
    • Low engine oil level or dirty/sludgy oil blocking proper VVT function
    • Faulty PCM/computer output signal
Way2Fast
Way2Fast
Sam
Santa Maria, CA
That makes for a few options. No rough idle or acceleration problems. I wonder if my extended warranty will cover this. Did 500 miles today at 80mph. Ran great
Ducati1098
Common Symptoms
    • Lower gas mileage
Main Causes
Wrong code. It’s P007B
what kind of front bumper do you have? Stock or aftermarket?
Way2Fast
Way2Fast
Sam
Santa Maria, CA
The report said no parts were needed. Is this something a Ford dealer could repair in a day
HBTFD 2.0
HBTFD
Georgia
24 F250 Tremor
If the intake is not blocked I am betting on a dirty sensor.
Ducati1098
That report is just generic information. The fix depends on the diagnosis.
LVS
Audi TT
Just curious; What temp was it outside, and what altitude ?
LVS
Audi TT
I’m not sure if the ECU adapts quickly to significant altitude differences especially over a short period time.
timhood
Tim
Several
It adapts faster than the Broncos can change altitude or the temperature can change or both.
