Charging While Flat Towing
NC_Pinz
Central NC
2022 Ford Bronco OBX w/ Squatch, 1975 Ford Bronco
Fordified1
Bob
Mid South Texas
No reaponses, did you find info elsewhere? I’m ready to flat tow except for the charge line. Towing with a 2002 American Coach DP.
Fordified1
Bob
Mid South Texas
How does it get its ground? I see a single hot wire. No description of how it hooks up.
dgorsett
colorado
F250, Mustang, Explorer
The RVI version. Quite a bit more expensive. Monitors rv and towed side
Ford Bronco Charging While Flat Towing 20231021_143744
Fordified1
Bob
Mid South Texas
Do these get ground from the MH through the hitch? Brake Buddy one doesn’t look like it has a ground wire to connect to the MH.
dgorsett
colorado
The RVI grounds on the towed battery AND through the 6 pin connector to the MH. They really emphasize grounding both.
73Corvetteman
Duane
Hudsonville, Mi
2023 bronco
I would definitely have some type of charge system in place. Everything being electronic on these new broncos puts a bunch of draw on battery. Gremlins start popping up if battery gets low and last thing you want when you get to campground is problem with toad!
ssmegapunish
Ben
Colorado Springs, CO
2022 Bronco, 2022 Lightning, 2021 F350DRW
I just used power from the 7 pin umbelical. There’s a voltage drop from tow vehicle to bronco that sometimes means you need a 12v dc to dc charger (basically boost voltage at bronco to a float charge voltage) if you want to charge to 100% reliably. It wasn’t needed in my case since the load is minimal and the battery should already be at or near 100% charge. I’d watch your voltage and determine if it is needed rather than adding a booster right away.
Yii-Haw
Robert
Corona CA
Dodge Durango / 66 Mustang
NC_Pinz
NC_Pinz
Central NC
I know its been some time, but did you end up installing this system? Also what brake system did you go with? Thanks.
I didn't. I actually bailed on towing the Bronco and spent $5k on a used Mini Cooper to drag along. I'm a little bummed that I'm not taking the Bronco with us on adventures but I just don't trust that it won't be damaged when I get there.
evofxdwg
George
Middle GA
2016 F150 FX4, 2024 Bronco Badlands Sasquatch
Im working on the same setup for the new Bronco that I have with two motorhomes and a 2016 F150 FX4 now with 40K+ towed miles on it.
On the first motorhome I had to add the Aux +12 wire to the 7 way connector since it wasn't there on the Ford motorhome chassis. For that one I added a 30A self resetting breaker at the motorhome chassis battery. Then I added a 30A self resetting breaker at the F150 battery and brought the Aux +12V to it. The wire I ran was AWG12 stranded.
The 2nd motorhome, on a Freightliner diesel chassis, had the Aux +12 wire already installed and a 30A fuse under the hood for that circuit. So I just used it as is. Have had no problems with the F150.
I installed a 7 way receptacle on the F150 at front and use a Curt umbilical 7way to 7way coiled cable. I will do the same for the Bronco, including adding a 30A self resetting breaker at the Bronco battery.
