Charge pipes issue
Dmorty217
Derek
Venice FL
Camery
I installed the AFE charge pipes on my 2.3l and since doing that 1000 miles ago 2 different times (the latest being today on a 90 mile trip home) the turbo won’t produce anymore than 1lb of boost. I’m taking it in for service Thursday but has anyone else run across this? If I shut the vehicle off for 15 mins or so the service engine light goes away and the wastegate resumes normal function until it decides to do it again. Now my check engine light is on which hasn’t happened the one other time this happened. I’ve since reinstalled the factory charge pipes and went for a drive and everything is normal minus the engine light. Again I believe this is a wastegate problem that has been documented in this forum but it didn’t start until I installed the aftermarket charge pipes. Put the factory ones back on bc I don’t want to have to argue with the dealership about fixing the underlying issue
Dmorty217
Dmorty217
Derek
Venice FL
Camery
Just to note with the turbo not working the bronco is slower than shit but man I get way better gas mileage!
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Did you check what code(s) was set? If the CEL is still on, there should be a code in memory. Don't erase it if you are planning to have your dealer look at it
Dmorty217
Dmorty217
Derek
Venice FL
Camery
Here are the messages I got through the app
Ford Bronco Charge pipes issue 84F75C02-CE1E-4745-A96D-0A643AA95432
Ford Bronco Charge pipes issue 2F569B20-6095-429E-BD97-5960F5BCFADB
Lèòn
Jersey
Ask Rick, he’ll know what to do
Ford Bronco Charge pipes issue 1666478195085
All cerealness, what the hell is going on??
Ducati1098
Probably just a coincidence. Doubt it has anything to do with the pipes. Just the typical wastegate issue seen before.
Dmorty217
Dmorty217
Derek
Venice FL
Camery
That’s what I think also but I had to ask others. My dealership is being stupid about shit so I had to reinstall the factory pipes which are shit compared to the aftermarket. Also have a aftermarket intercooler I am waiting to install now until the dealership fixes the wastegate issue. Spend almost 50k on a vehicle and they try and tell me I should remove my K&N intake and charge pipes. Mind you before I got mine I specifically asked them what would void the warranty and I quote if you modify or bypass the cat or put a downpipe on. Well I haven’t done either of those and I’m annoyed with 4200 miles on my bronco
RHeinz
Ric
Houston, TX
So, if I can summarize….
A) Your Bronco was working fine.
B) You modified it.
C) Now you‘re having functional issues perhaps due to the modifications.
D) You want Ford to fix it, so you removed the modifications.
E) Now it’s functioning without issues again.
F) The Ford Engineers don’t know shit compared to the aftermarket “engineers”.
How did I do? I’m not sure why you posted….
Dmorty217
Dmorty217
Derek
Venice FL
Camery
B) You modified it.
Ah yes I was wondering when one of you would arrive. The aftermarket cold side provides 70% more air to the turbo which isn’t a bad thing compared to the stock so say whatever you like. Ford engineers have plenty and I mean PLENTY of problems with a vehicle the have been working on for years and we are all aware of them. Move along if you have nothing to add. Yeah for 10 miles now the factory pipes haven’t caused a issue… for 10 miles. The issue is the wastegate not the pipes but please exert your wisdom
foremi
Bronco Badlands 2dr, Touareg V10, B5 S4 6spd Avant, YXZ
You would probably be able to hear it if it was leaking that much of the air charge from the turbo.
foremi
Dmorty217
Dmorty217
Derek
Venice FL
Camery
It’s not leaking from the turbo, the problem is the wastegate is stuck open and won’t let boost build. It’s random and whenever the vehicle is shut off for more than 5 mins it goes away for 1000 miles or so. Doesn’t make any sense and the wastegate issue is well documented and ford can’t just replace the wastegate for some reason it’s also involves the turbo being replaced. I would just buy a aftermarket wastegate and have it put on not through the dealer but no one makes one that I can find
Dmorty217
Dmorty217
Derek
Venice FL
Camery
Right.....
I’m not the only person who has done this to their bronco because that is also documented here but I’m having a wastegate issue so….
foremi
I was responding to your OP where you started with you changed the charge pipes. If it's so irrelevant why was it the first thing you said?
After thoroughly reading the post I'm not sure what it is you are actually expecting/asking?
Ducati1098
It has an electronic wastegate instead of a normal vacuum one which is why there are no aftermarket ones, at least not yet.
