Capable vs modular bumper differences (besides visual)?
WPSbronco
Austin
Arkansas
Black Diamond Bronco
What's the difference outside of appearance?
Bikeric
Tulsa
2022 Badlands LUX on 37's
You can unbolt the wings of the Modular. The Capable comes with fog lights and D-rings. Modular has hooks instead of D-rings.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
I didn't know that. Thanks!
Aliass24
Any noticeable weight difference between the two?
TheShark
I can tell you when I replaced the capable bumper on my WT with a mod I could take the capable bumper off myself, no problem, the mod required two people, I don't know the exact difference but it seemed to weigh a ton.
Brandonj83
Brandon
F150 Raptor
When you removed the capable bumper, can you use the mounting brackets from the capable bumper on the modular bumper? I have found a few mod bumpers for sale but most of them are missing the brackets and tow rings. The brackets are item 20 in the diagram below.
Ford Bronco Capable vs modular bumper differences (besides visual)? IMG_4881
Brisco2
2012 F350 XLT, 2018 Ford E350
I switched from a standard (plastic) bumper to modular and was able to use excising bracket and the same 3 bolts on each side. Should be the same for all 3 bumpers. If the tow rings are missing, you may need to purchase to complete the install.
Brandonj83
Brandon
F150 Raptor
Your right. I just looked up the mounting bracket part number for the capable bumper and it’s the same as the modular. I will have to buy the tow hooks separate it looks like.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I got the capable because I wanted stock fog lights for the factory switch. In hindsight, I wish I had the modular because adding the factory switch is much easier than swapping out to the modular, and the modular has a ton of aftermarket support and add-ons ;)
MayhemMike
Mercury
The don’t sell any legitimate aftermarket bolt on accessories for the Capable bumper.
