Capable Bumper Shackle Removal
Jeffola
Southeast Florida
2023 Bronco, 2023 Hyundai Santa-Fe, 2019 GT350
I removed and added these from Ford performance, now I can tow easily behind RV. This Bronco is the most capable fun vehicle I have ever enjoyed. Just a small amount of trimming. If I decide to go somewhere I need the hooks, pop the plastic cove, 3 bolts and done.
Care to see the original ones? I'd like to powder coat the entire thing (in pieces) so A spare set would keep the bumper on the bronco.
gobluedave85
dave
f150
How much trimming was necessary to get these to fit the capable bumper? Was it just trimming of the plastic surround? Love the look.
GI_Jo_Nathan
Jonathan
Yep not much is needed and just on the plastic trim piece. If you look closely at the left one in the above pic, you can basically see all that is needed right above the tow point.
ETA: This pic of mine gives you a pretty good idea as well.
Ford Bronco Capable Bumper Shackle Removal 20230830_171628
Secampbell7
Sean
Bronco Heritage
What did you use to trim that so cleanly? Thinking of using a Dremel with a cut off bit.
GI_Jo_Nathan
Jonathan
Yep I used a dremel with a cut off wheel to kind of slice the flat part that goes to the back, and used a grinding bit to slowly eat at the rest. The first side felt like it took half an hour, second was done in like five minutes.
ManuelNY
Manuel
Queens, NY
Bronco Badlands 2 Door 2025 Just Ordered
Just get under with s pry tool and pull. They’re only clipped in. Give a good tug.
Thanks. So I am assuming that sensor would have a wire that has some slack so when you pop the covers out you won´t damage anything, am I correct? In other words, can you just pry the covers off without worrying about the parking sensor? Thanks guys!
ManuelNY
Manuel
Queens, NY
You don’t have to remove the whole thing. Pop off the plastic knock out the pin with a punch. Remove the rubber grommets and paint
Very helpful, so when you pry off the shackle covers , the parking sensor wire has enough slack that it won´t get damaged, right?
ManuelNY
Manuel
Queens, NY
Sorry, I don't. They did their own mix and testing...and came out with a perfect result.
Thanks! Someone else said it is pretty close to BMW´s volcanic orange paint.
broncogenx
Ryan
US
2026 bronco Outer Banks Sasquatch
What did you use for paint ?
