Capable Bumper Shackle Removal
Scotty_A51
Scotty_A51
Massachusetts
2022 Bronco Badlands
Is this all that separates the capable bumper from tbe standard one? I have the standard bumper with fog lights on my truck. Could that plate be added behind and a cutout made for the shackles I wonder?
Good question 🤔
rancid53
Russell
NE Texas
Frontier Prox4
Just get under with s pry tool and pull. They’re only clipped in. Give a good tug.
That worked like a charm. I didn’t even have to pull the bumper all the way off… I was able to loosen the bolts enough to take it away from the bronco and drill the holes I needed so I could mount my light bar.
Ford Bronco Capable Bumper Shackle Removal 8F51614D-2672-4EF5-8732-F5C9ED0515D7
Scotty_A51
Scotty_A51
Massachusetts
Hell yeah, that looks real good 👍🏻
Webbie44
Roger
Illinois
2016 Jeep 2dr Rubicon, 2021 Toyota 4Runner, 2023 Chevy Silverado ZR2 Bison
I removed and added these from Ford performance, now I can tow easily behind RV. This Bronco is the most capable fun vehicle I have ever enjoyed. Just a small amount of trimming. If I decide to go somewhere I need the hooks, pop the plastic cove, 3 bolts and done.
Ford Bronco Capable Bumper Shackle Removal 20220710_155145-jpg
Ford Bronco Capable Bumper Shackle Removal 20220710_155251-jpg
Ford Bronco Capable Bumper Shackle Removal 20220710_155141-jpg
I was thinking about doing this same modification when I get My Bronco. Did it require removing the bumper or just the plastic cover to swap out the shackle mounts? Where did you have to trim? Do you have any close up photos of the area where you trimmed? Looks great to me!
Rjacks258
Randy
Punta Gorda, FL
2022 Ford Bronco, 2019 Ford F250, 2009 Ford Ranger
Ok, question for the capable bumper. Can those covers be purchased from another model to give access to those anchor points? Maybe a black diamond or something?
Our Wildtrak with capable has the tow hooks under the bumper, I like the look of the shackles up on the front of the bumper, but ours is covered. Seems that part is removable once the bumper is down.
BeardedRanger
IL :-(
Bronco Black Diamond; Ram Rebel 1500
What exactly did you have to trim to install the Ford Performance Tow Hooks? Do you have any photos showing what was trimmed? What other flat towing equipment are you using? Thanks!
Wilkerw
William
2022 Bronco
How do you get the pin out of the d ring to separate it
Bearcat1
Travis
2017 Expedition Limited, 2006 BMW 330xi
Wilkerw
William
2022 Bronco
Thank you, I have a spate set I can practice on.
GI_Jo_Nathan
Jonathan
If I'm understanding you correctly, you don't have the capable bumper. You have the standard plastic bumper. I don't believe you can adapt it to this.
Ford Bronco Capable Bumper Shackle Removal bronco-bumpers
mjsalpeter
Marc
2023 Ford Bronco
Update: all assembled back and went together perfectly. So it can be done taking the pins out and painting or powder coating
How do you access the 4 bolts on the shackle holder? How do you remove that part of the bumper? Thanks
mjsalpeter
Marc
2023 Ford Bronco
I all told my salesman buddy like every day, “Please remember to not let them install the front bracket.” Then I showed up right as it got delivered, got in and pulled the bracket out. Walked to the trash can and threw it away. Everyone there laughed.
I like these but I'm ;looking for them in Gunmetal Grey. Does anyone know if there are other Shackles or Tow Base mounts that fit the capable bumper? Thanks
Chesuncook
New Gloucester, Maine
2023 Bronco 4 dr
Hi Jay, I am am new to this forum. Just bought a 2023 Wildtrak with the capable bumper/D ring tow hooks like yours. I would like to change them as you did so I can tow it behind our 40' Tiffin Bus. We have a Roadmaster tow bar and I was looking at the adapters with a 1" opening meant for tow hooks on a Jeep. Could you please tell me how thick your new tow hooks are? I heard they are 1 3/16" thick. What did you do to hook your tow bar to them?
Thank you in advance for any help and insight you can offer me.
