Cannot insert fuel nozzle or the funnel
wheelsco
CO
2023 BL SQ 4D
Went to fill up last night and could not get the gas stations fuel nozzle all the way into the tank, gets caught on the second flap. Tried multiple nozzles at multiple gas stations and same thing. Tried the fuel funnel from the trunk and same issue.
Attaching a pic of the inside flap/door that the nozzles get stuck on- is there supposed to be a cover on it that broke off? Seems there are tabs sticking out of it and the top of the nozzles/funnel gets stuck on the bottom one. The other pic shows how far in the funnel goes, cant get it in any further.
Any chance someone can take a quick of their interior to see if it looks the same? I cant put gas in my bronco, which is kind of an issue : )
Ford Bronco Cannot insert fuel nozzle or the funnel interiorFla
Ford Bronco Cannot insert fuel nozzle or the funnel asFarAsItGoesIn
wheelsco
CO
2023 BL SQ 4D
Thanks! And ugh :( Car is 2 months old, filled it up maybe 5 times without issue. Curious if I can snip off the little tab at the bottom but worried needs suspected missing piece to keep fumes in.
Feel like this is missing (attached)
Ford Bronco Cannot insert fuel nozzle or the funnel missingPiece?
PWillette
Parrie
Maine
Based on your pictures sure looks like you're suspicions are correct. @flip may be able to confirm if it is a replaceable part.
Area51BS
Ron
Badlands non SAS 4dr 2.3
So they had to redesign a fuel fill for the Bronco? Gas fills have been around how long and never break?
Imaginary Friend
Southern MN
A passel of Fords and a Jeep JL Rubi
To think, the 56-year-old car that resides in my shop, which I've owned for 37 years, has never had an issue accepting a fuel pump nozzle.
Let's continue to make things more complicated than they need to be....
wheelsco
CO
2023 BL SQ 4D
I checked out another Bronco and yep, there is a flat cover piece on the interior flap that must have broken off on mine and gone down into the tank. grrrrrrrr
0ne
Nate
CO
Flex
Gotta insert and remove the fuel nozzle gently, yay for cap-less fuel fillers!
wheelsco
CO
2023 BL SQ 4D
never had a single issue in 10 years with my raptor's cap-less filler. the bronco ones just seem unnecessarily dumb
USSCajun
‘23 BD, Sas, 2dr
I filled up the other day, pump popped off meaning full, I drove away looked at gauge and only half full. ??
0ne
Nate
CO
Flex
The capless filler in my 2011 Flex is much different than my Bronco, agreed. The first time I filled the Bronco I could tell it had to be treated with kid gloves, with the way everything looked and felt…not to mention the movement in the filler neck!
AZ_Liberty
2007 Expedition
Emissions. Ford switched to a capless fuel fill several years ago. Dad's 2017 F-150 is capless.
Of course, the more complicated something is...
2023bronco
location
vehicles
No joke. It's moves like it's held in place with rubber bands.
Area51BS
Ron
I’m aware, but never knew of an issue until the Bronco came along.
