Can
Hornet
Ford Explorer
If you like the stock wheels can you put a bigger tire on them? Can you put 33's on the stock Big Ben wheels thst come with 32's?
Lowcountry Bronco
William
South Carolina Lowcountry
Yes, as long as you have the clearance, tire specs give recommended wheel widths along with height and width of the tire. Now how much room you have under a BB I don't know, I'm sure there will be all kind of aftermarket suspension choices within a few months after the first Bronco hits the streets.
Markubis
New Hampshire
Ford Focus, Ford Ranger XLT, Can Am Ryker
Diameter yes but I'm not sure about tire width using the stock rim.
Hornet
Hornet
Ford Explorer
Thanks. I'm not going Sasquatch so when time to replace the tires is like to go a little bigger if possible. .
lowmpg
Ryan
Maryland
F350
Yes you can absolutely add larger tires, the rim width will allow for it. The issue you'll most likely have if you go over 33's is related to the suspension and rubbing you'll have on parts of possibly the suspension, bumper, fenders. Given that the 35" tire pkg comes with a higher suspension, IMHO that means Ford knows that 35's on a lower suspension has a chance to rub.
BroncBro
2019 Tacoma 4x4
If you go to the manufacturer website of the tire you’re looking at, they always list approved wheel width for all of their tire sizes.
For example, most manufacturers list a 12.50” or 315mm width tire as an approved wheel size of 8” to 12” wide.
VegasKoop
Las Vegas
Lincoln MKS
I'm assuming the BBs are 7.5? Would that limit the upgrade to 275s?
BroncBro
2019 Tacoma 4x4
275s should be just fine with 7.5” wheel. Just check with the tire manufacturer for the approved wheel size.
If it helps any, here are all the tires available on each trim.
Ford Bronco Can 7ACB1EB6-F35E-4875-8C0B-E04B144A57C2
dragon6172
Virginia Beach, VA
2021 Bronco FE
I think the overland concept Bronco makes it obvious that 35s will probably rub without a suspension change
gryphon1231
dj
Miami FL
na
yes and no. depends on the width of the tire you want to run. tire hight is not is not limited by wheel size tire width is.
VTBronco
Sam
Vermont
Honda Civic
Ford Bronco Can E057F3F8-6912-4530-B9D2-629D389A1CAA
So technically speaking, 275/70/17 could fit on the BB (standard 255/75/17)? The rims would work with the new ones. Is there a way to know if there will be any issues prior such as rubbing? Would 265s be better?
