Can Tires be Too Big?
MNBigfoot
MN
So you wouldn't want 4.7 gears, better suspension and front and rear lockers from the factory if it was the same price you paid?
Maybe you don't care about them now but what if one day down the road you decide to actually get into off roading? Wouldn't it be nice to know you already are equipped to do so?
x2. For me a rear locker was a must and in my configuration the Base with the Sas package was less that getting only a rear locker in any other trim. I could add the ford full skid package and sliders for the cost of a non-sas BD. At that time Sas take-offs were going for $1800-2000 and I could get a set of BD take-offs for $700 if I ever wanted to drop down. I looked at it 100 different ways, and no other trim made and sense unless someone had to have the mid-package, or vinyl seats.
Oldhippie
Barry
Santa Cruz, Calif.
yeah in hindsight I wish I had kept my original “base Sasquatch” order and not jumped on the “heritage“ train wreak…ended up paying the “ford tax” on a big bend for no real features over a base And waiting a extra year…
Patrickgault
Patrick Gault
South Carolina, USA
Ford Bronco, 2022 Outer Banks.
At some point you've got to consider road noise and weight. Any suggestions on a wheel manufacturer that is known for light weight wheels?
DMSCS
Matt
San Francisco, CA
Bronco 2DR Manual
Taller tires certainly serve a purpose, and are beneficial for ground clearance. I think 37's look good on 2 and 4 doors. Some dudes are on 38's, and that APG Pro runner Bronco is on 40's, and looks beastly.
I put 34.4"' (315's)tires on my Badlands with a small lift, and still scraped a bit around Moab. 37's would help lift that belly up for sure though.
Which tires did you go with? I know there are 34" versions of the 33" BFG K02s that come on the non sasquatch tires. Was thinking of going with those when my stock ones wear out.
vrtical
Doug AI
GSMNP, TN
Fords
my 17x9 Welds wheels are 21.8 lbs a piece. I put true 37 ATs on (Mickys) and only added 7lbs total additional corner weight over OEM on my braptor. Although KO2s are extremely light and undersized OEM wheels are heavy as hell.
Sitruc_btb
Curtis
Chandler, AZ
2022 Bronco Badlands
I chose Firestone Destination MT2. Not much info or reviews besides the typical auto mags wheeling in a new Willys Wrangler equipped with them. I also got employee price on them, cant beat that.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Because in the 90s America associated Firestone with the biggest Recall ever. Several people I know have gotten the new firestone destinations free with purchase of equipment tires. None of them wheel or drive in bad weather so no real reviews. They use to be one of the best tires for offroad back in the old days.
Sitruc_btb
Curtis
Chandler, AZ
Was that with the old Explorer and tire pressure fiasco?
They worked well enough in the Utah slick rock. Not much inclement weather down here in AZ, though they handle fine in wet conditions.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Yeah, heard there were some Explorers who pulled into Arizona Jack-in-the-Boxes back in those days and were never seen again... 👻
I thought it was the tread delaminated and caused cars to dramatically lose steering. So people on highways were jackknifing and rolling. That was one of those WTFWTT kinda deals.
Sitruc_btb
Curtis
Chandler, AZ
Im not 100% positive on the whole story, but I think the Explorers were prone to rollovers, either during impacts or defensive driving, so Ford and their infinite wisdom decided to drop the tire pressure to xx-psi, which helped with rollovers, but now at highway speeds, caused the tires to overheat because they are underinflated, resulting in the delamination and whatever carnage happened afterwards.
I think Firestone was the factory tire, and there may have been factory defects in the tires as well, but Im not sure.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Ford Exploder and Firestone Cover-Up was all over the news lol. Add in that the Ford Explorer was the hottest selling vehicle for a while. Literally killed the full size bronco and people at the same time.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
That all sounds correct. If you remembered that (and didn't look it up), you got a good memory! lol
Sitruc_btb
Curtis
Chandler, AZ
Not that long ago, I read about it, either from an article or wikipedia, something like it. A co worker mentioned it and piqued my curiosity.
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
From my first hand experience (94 Ford Explorer Limited), the blame should have been put on Ford. But everyone pointed fingers at Firestone. Owners at the time somehow couldn't read the side of a tire for recommended inflation. Instead they chose to read the sticker in the door jam which Ford recommended a low air pressure. I recall that it was 26 PSI on the door jam sticker. Then people blamed the tire when the tread separated driving 80mph on the highway. I was fortunate that I was able to read the recommendation from the tire manufacturer and not Ford. Consequently, I ended up getting 3 full sets of tires in recalls. Each time, I insisted on the Firestone. There was nothing wrong with the tire.
