Can someone explain our HVAC system?
Roofus
Swamp
M3/Bronco
I've now had my OBX for roughly a year and a half and this vehicle has one of the oddest HVAC systems I've ever encountered. I'm very curious if it operates differently based on outside temp.
I keep my temp at about 70F almost year round. During the summer months, 70F blows cold air with A/C turned on. Once the outside temp dips below about 60F, the HVAC blows hot air at 70F internal even with the A/C turned on. During summer, recirculate stays on at all times. During winter, even with A/C turned on, recirculate turns off at about 60 seconds and needs to be turned back on if desired.
I've noticed other quirks as well. What in the world is going on with this crazy HVAC system?
userdude
Denton, TX
2023 2dr Badsquatch
Mine (I think?) always blows cold air if I have AC on and the inside temp is warmer than the dial temp. At a certain point (75?) it will start to blow warm air (I guess because "cold" air isn't 75?).
I've been noticing these odd quirks too, so interested what others say.
Nickhick
Nick
Bath twp ohio
F150 xtr, vw passat
In short, it blows
kr_1315
Kevin
Houston, TX
F150, Tundra, Explorer, IS500, '23 Bronco 2DR
Is there any way to just run the Fan ?
No AC and no heat. Just fresh air from outside ?
Always have the windows, but then lots of extra noise and sometimes window wobbling
Select which vents you want the air to exit from, then deselect the AC button. Fan speed is now controlled manually through the switch.
EilersPark
Hans
Leander, Tx
2012 Dodge Ram 1500 4x4
I have noticed the same thing and I thought it was odd. I am really noticing it now that its 80 one day and 45 the next. I am going to get a laser temp gun in there and try to capture this empirically.
Rydfree
Benny
Alabama
The system will blend hot air with cold air depending on the inside temp to meet your setpoint. If it is set at 70 and it is 80 then it will blow cold only but if it is near the setpoint it may blend hot air to keep it at the desired temp.
Roofus
Roofus
Swamp
M3/Bronco
Bschurr
NY
Also keep in mind that A/C doesn’t necessarily mean cold air - it means conditioned air which can be warm or cold depending upon the set point and ambient temperature.
Roofus
Roofus
Swamp
M3/Bronco
That makes sense. Unfortunately, the difference between 70F and 68F (for me anyway) during winter months is a choice between the surface of the sun and Antarctica. I'm looking for more of a light Maui breeze. 🤣
Moving Chicane
Los Angeles
Subaru
Our new Bronco doesn't have the same issue, but close, and it is weird!
With the AC On and Recirc. On, the system seems to open to outside airflow (at any temperature inside or outside) when cruising at more than 60mph for a good length of time, or going up grades. As if it's trying to cool something in its own system. I have no idea what is going on, but it works when I need it to, and acts funny at the strangest times. Not a showstopper, just intriguing for now. Who knows.......
Roofus
Roofus
Swamp
M3/Bronco
Have no idea what you're saying
How do you turn-off the "desired temperature" ?
How do you select vents ?
Which switch is now manual control ?
They mean if you click the button circled in yellow you get an onscreen prompt to choose the vents, then you use the lever circled in blue to adjust fan speed. All of which you probably already knew.
Ford Bronco Can someone explain our HVAC system? IMG_4086
Zulu7
high desert
Broncos & Bikes
They mean if you click the button circles in yellow you get an onscreen prompt to choose the vents, the you use the level circles in blue to adjust fan speed. All of which you probably already knew.
Much thanks. I didn't know any of that
Area51BS
Ron
Badlands non SAS 4dr 2.3
Ford has decided to complicate even the non auto ventilation system. It randomly will allow outside air to refresh the cabin from what I can tell. Totally annoying especially when it’s cold outside and it blast you with freezing cold air. I drive an umbrella top so air exchange is a non issue. It’s been this way on our 2 Bronco sports, Maverick and my Full size. Only fix is you turn recirc on/off to put it back to where you had it set. I’m sure just AC on/off does the same. Wish it were like old days . AC on, cycles by pressure and a switch. And damper doors for temp controlled by user. It never changed while driving. And no strange looks from passengers going WTF was that.
Gizmo
Randy
Grand Rapids Mi
2020 Alfa Romeo Stelvio 2020 Porsche Macan 23 OBX
You may want to sit outside with your truck, and play with the settings and different functions a bit-I do agree some of them are a bit odd with the HVAC
Ducati1098
Ford Bronco Can someone explain our HVAC system? IMG_2362
