Camping trailers
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
i will second that Mammoth are incredibly built.
at the weight limit we have, you’re going to struggle to find a well-made camper with interior amenities (kitchen, shower, toilet) that falls within your truck’s limit. Your badge says Badlands, in which case you’re limited to 3500lbs, not 4500lbs (Braptor only). Of course you can exceed that weight limit but don’t until you’ve watched a few videos of the risks of what exceeding your tow limits can do.
re toilet and shower
In the under 4500lbs off-road capable category, you have as an option an outside shower (i have a joolca with a double shower tent, and this is a fantastic unit and solution for showering.) And for a toilet, well, i think I have the best solution of anyone. I am known to my friends as a “heimscheißer” (you can look it up for a laugh.) I love to camp but am unwilling to conduct my morning ablutions in a pail. I’m unwilling to use any of the options that most others will suggest. My solution is the Laveo Dry Flush, which is a normal sized toilet (made of ABS, so carryable). It uses mylar bags and operates like a diaper genie. Do your business, press the flush button, and the machine encapsulates your offerings. The unit holds 10-15 of such contributions before you lift the lid, pull up the sides of a black plastic bag in which the myler bag has been resting in, and you throw the whole thing in the trash. There is no smell. I keep it in the back of the Braptor, in hot weather and nary a whiff. Liquids are congealed by sprinkling in a congealing agent before you go potty (sort of like a talcum powder), so when you throw everything away, you pull up the black trash bag inside the unit, it gathers up your sealed mylar tube-of-grossness (again, think Diaper Genie) and you just drop all your encapsulated moments in a trash bin or dumpster, no chance of leaks, no smells. And you won’t be like the jerks who shit in the woods, and barely cover their mess and leave toilet paper blowing around at dispersed camping sites.
downsides? Cost of the unit. A Home Depot buck or a shovel or cheaper, but are you really a savage? Cost of the consumables: The myler packages, each good for 10-15 uses, are spendy. You’re creating non-recyclable landfill, and size of carting around a toilet. But you either set up a poo tent or use one of the “rooms” in your shower tent, and you’re either the object of envy or the subject of derision by your friends. This is a winner for all but the most feral of girlfriends and wives.
the orange tent in this photo is my single lav tent at King of the Hammers this year. If doing #2 in the wild is going to be a sticking point with your spouse, this is an expensive way to definitively solve it. There’s also the Wrappon toilet from Japan. Same idea, smaller, but you get a little sealed bag everytime you go. That works if you have a trash to immediately drop it in, but not if you need to carry large ziplocks of poo in the back of your truck for a few days.
Wrappon: https://wrapponusa.com/Trekker-WT-4-Toilet-System/
Laveo Dry Flush https://dry-flush.com/
Joocla heater: https://www.joolca.com/products/hottap-v2?variant=43416580685858
Joolca 2-room Tent: https://www.joolca.com/products/ensuite-tent-double
Single Poo tent (the orange one)
NEMO Equipment Heliopolis Privacy... https://www.amazon.com/dp/B083BHD96S?ref=ppx_pop_mob_ap_share
For showering and dish water in the Bronco I keep this behind the rear seats
https://www.ironman4x4.com/products/50l-tapered-water-tank-13-gal
on sale for 25% off for memorial day
if you have a Brap and can tow 4500lbs, you could do this:
https://www.rvsofamerica.com/shop/karavan/
and personally i really like OGT Off Grid Trailers, and they have several models to chose from that fit in either 3500lbs or 4500lbs ranges. But no toilet, they offer a shower but it’s outside, as is their kitchen.
I have a Hero Camper from Denmark but I cannot recommend it for two reasons: there’s zero factory or dealer support in the US (there was when I bought mine but dealer support ended in 2022 and factory support appears to have ended earlier this year when the guy who was importing them wound down his business due to lack of investment by the factory in growing the US market). It’s also a soft-roader in stock form. i have hardened mine extensively to address the limitations, at considerable expense. If I was doing it again, I’d buy a Mammoth.
I live around the corner from Off_The_Grind on Instagram, David Jenkins. He now works for Mammoth, which is in Woodinville, WA. Should you want to have a conversation about their to models, I can connect you.
Can I see a photo of your water setup behind the seats?
Darcyjs14
D’Arcy
Seattle
1970 Ford F250 Camper Special 4spd
For sure, when I get back to Seattle on Sunday. It’s this tank.
I can stand it up against the seats when they are up or I lay it down across the seatbacks with the screw cap facing forward and behind the driver if the seats are down. I use 2 ratchet straps to hold it in place. Came with a valve and hose and gravity feed has been sufficient so far.
Ford Bronco Camping trailers IMG_7401
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
I'm pulling an Xpedition Voyager, but she won't like that one! It's kind of like tent camping, the only thing you do inside is sleep, but it's a roomy square drop instead. You might want to rent something that she might like before you buy anything because if she's not into it, it will just sit and go unused.
TheKim
Kim
I've been pulling a Jayco for about a year now, and it's gone well. I have a large stabilizer hitch, which helps a ton. It's empty weight is about 2800 last time I checked, and fully loaded it's about 3300.
It can feel a bit heavy on a long steep grade, and you'll want to watch temps with those two turbos, but it'll do it great 💪
I've got a couple videos of me towing it over small obstacles, and can share the links if you're interested.
I'm also in a 2.7L Badlands Sasquatch, but I'm only on HOSS 2.0 and no fancy stuff.
Good luck and have fun!
Ford Bronco Camping trailers PXL_20240831_001405948
Ford Bronco Camping trailers PXL_20250413_021116069.MP
Big Pony
Subaru Ascent LTD '20
I have the “Eclipse” version of this one:
https://intech.com/rv/models/sol/dawn/
I am new to off-roading with a 2024 Badlands SAS 2.7L hard top. I have done a little off-roading but nothing major, probably some medium trails. I am trying to get my wife interested in trail camping but need a trailer under 4500lbs with ALL the amenities. Won’t be out during hard winters and will be out for 1-week stretches to start with. She’s (wife) a mall queen. Any suggestions?
I’m a fan of the mammoth and the other rugged ones other folks have suggested, but this one has served me well and it was a compromise since my wife is also very needy when it comes to camping, especially if it’s boondocking 🙄.
I think it’s budget friendly. Mine is 2800 lbs. dry and fully loaded maybe 3400 lbs. which is well within the Bronco’s suggested towing capacity. I have taken it on mild trails, but I wouldn’t venture with it on more rugged or rocky trails. Whichever route you decide to take, I highly advise getting some helper springs or airbags to help with the rear squat when towing. Good luck!
I have the “Eclipse” rover version of this one:
Jamyers77
Jon
PA
Nissan Xterra
https://hikertrailers.com/
check out the midrange XL and Extreme Offroad
This was my go to. I had tons of gear from hiking/camping over the years and couldn't justify the money on a full galley or other things I already had. It's basically a shell, then you add a la cart what you want. I got it late last season, but intend to diy add ons as the need arises.
Ford Bronco Camping trailers 20241026_082554
Ford Bronco Camping trailers 20241006_120315
Big Pony
Can you share the brand/model of the stabilizer hitch you use? I’ve been looking for a decent one but can’t seem to make up my mind! Thanks.
HoosierDaddy
__ Eric
NW. Indiana
New wife with interests that align with yours, unless separate vacations are acceptable for both of you.
I don't see Mrs. Mall Queen enjoying "offroad" trail camping.
or as noted by others, get a proper tow rig and a "Glam-per" , She might like that, it's braggable.
HoosierDaddy
__ Eric
NW. Indiana
under 4500lbs
3500max for the Bronco.
I'm certain it can handle more, but 3500 is what it is rated for.
The Ranger is rated considerably more than that, as I recall, 7500lbs if equipped properly.
TheKim
Kim
