Camburg
Camburg
Huntington Beach
2020 Ford Bronco
Our Camburg Bronco is running our X-Joint XL Trail Series Long-Travel Kit, paired with our Camburg Kinetik Series Billet UCA and Links.
Also running our Camburg Bump-stops!
These parts utilize our new Camburg X-joint XL for increased strength, longevity and high misalignment, allowing for maximum wheel travel. The larger X-Joint XL is an extreme performance, all-weather, all conditions, high angle ball joint. These are much higher quality, considerably stronger and have an improved boot design that allows for higher angle use, better greasing and increased longevity.
Camburg Bronco Billet Upper Control Arms
Camburg Bronco Raptor Billet Upper Control Arms
Camburg Bronco/ Bronco Raptor Suspension Systems
Valhalla
Valhalla
Chattanooga Tn
Bowl it?
87-Z28
Andy
BMW
What are the specs of the “X Joint XL”
Detailed specifications for ball joint: INCREASED angles. 🙄
Just in case you are not sure. Increased means more plenty good. So like 2.1 degrees is increased compared to 2.0. Duh.
