Cam Phaser Issues
Obiwan
Southwest
Don't care to share personal info
The other individual with issues Is similar time frame build I think.
I would love to say that maybe they have ironed this out with motors in 23' but being this has been a thing Ford just can not get right for multiple motor generations I think that would be a laughable statement.
Let us know what unfolds.
vrtical
Doug AI
GSMNP, TN
Fords
Whats ironic is FP created some better ones in mustang land for this issue, but yet after what 6 years, they still can't get them right in the Ecos. I never had the recall on my 19 F150, but I am sure it was going to get it at some point.
Raptor911
Raptor911
Broadlands, VA
You need to find a better shop. I find it hard to believe that they have to take the engine out.
Some shops actually lift the F150 body up from the frame to expose the engine and get better access.
I have it on the 2.7 in my Bronco. They have to pull the 2.7 completely out to repair. It's such a large amount of work that I have to live with it for over 3 months before my dealer can get me in.
There's another Raptor owner in this thread with the issue:
https://www.bronco6g.com/forum/threads/cam-phasor-rattle.39240/post-1724494
Holiday
Nate
Parkville, MO
Bronco Badlands!
Tye
Tye
Tye
San Francisco
Porsche GT3, Landrover Defender V8, BMW X3 Msport
UPDATE: After dealer inspection it is the cam phaser. So our motors are susceptible to this issue as well. Bad news is parts are on backorder so no ETA when it can be repaired.
Tye
Tye
Tye
San Francisco
2nd UPDATE: On the Bronco Raptor, the motor needs to come completely out for the repair.
monsterfd
2014 raptor widebody 37s, 2018 raptor 2018 JKU 35s
well, shit. thats not what i wanted to hear
Tye
Tye
Tye
San Francisco
Update 3: The parts have been escalated to an emergency order. Not sure what that actually means or if it means anything at all.
GSSHEEP
ME
37RAPTOR, GT500CFTP, GT350R
Just Curious, when did you get your bronco raptor and how many miles do you have on it ?
Tye
Tye
Tye
San Francisco
October build date. Received it in November. 1600 miles
GSSHEEP
ME
Thank you. I have a bronco raptor coming to my dealer in approximately 2 weeks and now I’m nervous.
Tye
Tye
Tye
San Francisco
Notes from service record:
2206 ENGINE RATTLE ( 42 ) 6256 REPLACE ALL VCTS.
PERFORM VEHICLE INSPECTION FOR ENGINE NOISE DURING COLD STARTUP AND CONFIRM CUSTOMER CONCERN. ALLOWED ENGINE COLD SOAK, DURING INITIAL STARTUP A RATTLE NOISE COMING FROM FRONT OF ENGINE UNDER FRONT COVER.
CHECK ENGINE OIL LEVEL, FOUND LEVEL OK, CHECK OASIS FOR ISB, NONE FOUND, CHECK TECH SUPPORT AND FOUND FEW VEHICLES WITH SAME CONCER.
CHECK VCT SOLENOID OPERATION, BY UNPLUGGING VCTS NOISE REMAIN WITH NO CHANGE REQUIRE FURTHER INSPECTION,
VCTS
REMOVAL OF VALVE COVER TO CHECK
FOLLOWING WSM SECTION REMOVE AIR INLET PIPE, EVAP PURGE VALVE, IGNITION COILS & THROTTLE BODY, DISCONNECT WIRING HARNESS AND REMOVE L/H VALVE COVER, USING AN ADJUSTABLE WRENCH TO ROTATE CAMSHAFT, FOUND THAT INTAKE CAMSHAFT ROTATE INDEPENDENTLY FROM SPROCKET ON BOTH DIRECTION (NOT LOCKING ON PLACE ).COMPARE TO EXHAUST VCT IS LOCK AND NOT ROTATE.
Interesting take away here is this in particular: CHECK TECH SUPPORT AND FOUND FEW VEHICLES WITH SAME CONCERN. So, I guess mine is not the only one that has been reported to ford and requiring a fix, just no one else is posting about it.
Raptor911
Raptor911
Broadlands, VA
Don’t read into this. It has nothing to do with when your truck was built or how many miles it has or what oil you were running. Goto the f150 raptor forum, there are thousands of post about cam phasers. Not all trucks has this problem. Ford had being dealing with this issue across different engine platforms and just consider yourself unlucky if you get it and there is nothing you can do to prevent it
Ducati1098
There have been numerous posts about phaser rattle and issues on here. Unfortunately it’s very common.
Tye
Tye
Tye
San Francisco
I was referring to Bronco Raptor specific cam phaser issue. I clarified with my service that statement was Bronco Raptor specific.
