Hi, i need help with low boost issues
turboelvis
Elvis
hiltown Pensilvania
2024 branco raptor
Hello, I got question about boost levels
I just installed JB4 tuner and in map 4 is says 4psi over stock I only sow 17,9 psi ?!
Is the stock psi in sport mode 15psi?
Terry@BMS
Simi Valley, CA
2021 Bronco 2.7
Boost is additive based so it depends what your map0 or factory boost is! Post up some CSV logs if you'd like us to check them out.
turboelvis
turboelvis
Elvis
hiltown Pensilvania
2024 branco raptor
Map0 was 15psi , I know jb4 it’s working but 15 psi seems low ?
Ape Factory
Michel
Audi RS5/Ford F150/Infiniti QX70S
Pretty sure the stock boost level is around 18psi max but that'll depend on atmospheric conditions. A Ranger Raptor pushing 20psi blew apart its charge pipe. Linky: Boom!
I've not heard of that happening on the BRaptor but it'd be interesting to hear from some of the others who are pushing things more. Me? I'm stuck at stock boost levels for another seven long years.
turboelvis
turboelvis
Elvis
hiltown Pensilvania
2024 branco raptor
Seems low 14 psi max boost stock . If some one else have same number it’s means it’s normal .
The owner before me leased this Branco , maybe dealer did something?🤷
Ape Factory
Michel
Won't be driving today but I'll check my numbers and report back. I'm at about 700-900ft. elevation. Not sure I have anything to get a DA reading unfortunately.
Bschurr
NY
Stock is approx 18 PSI
I have the FP Tune and regularly see Low 20s on a hard pull.
Are you sure the JB4 tune was properly installed (and, still active).
turboelvis
turboelvis
Elvis
hiltown Pensilvania
2024 branco raptor
Thank you to Terry from BMS , really responded fast . He checked jb4 log and its works like it shut no issues there . I probably will go to local ford dealer to ask them if they see sow same level off boost before
Yes, all installed good. On map 0 stock 14 psi , switch to map 3 17,9 psi. Map 3 ads 4 psi so it’s working fine
Bschurr
NY
14 PSI is low. You should be seeing 17.9 PSI in stock form and once tuned, increases from there. Good luck!
TheKim
Kim
(Mine is not a Raptor, only the 2.7L)
Mine will push 21-22psi with the ProCal tune under load.
If I control the throttle the right amount (not to the floor) I can keep it between 17-19 for a good pull.
turboelvis
turboelvis
Elvis
hiltown Pensilvania
2024 branco raptor
Shut I go to the local ford dealer ? Can they update the software maybe ?
Ape Factory
Michel
Personally I'd unplug the JB4 completely and see where you're at. I know it "fools" the ECU so perhaps this is why it's reading low. It's not an actual boost number but the fictitious one fed to the ECU by the JB4.
turboelvis
turboelvis
Elvis
hiltown Pensilvania
2024 branco raptor
I will try it . Tnx
