Bronco wouldn’t turn off???
maybachmarra
dakota
wisconsin
bronco
I installed putco illuminated bronco emblem. Tapped into fuse 25 however mistakenly didn’t use a 10 amp and a 7.5 amp, only a 10 amp. Everything was fine for a few hours/starts. A few hours later the bronco wouldn’t turn off. Car also gave me parking brake error, low power error, and every other error you can think of. Took to dealer who is stumped, says battery won’t stay charged for more than a few minutes.
any ideas?? Car only has 9k miles
WarthogJr
'21 Bronco Black Diamond
Remove whatever you did (return to original state 100%), then charge the battery. If everything behaves after a day or two of driving, start the installation over. This time, be super diligent about using all correct gauge wiring, solid connections, switch, fuses, and grounding. There are only so many variables, and it’s not likely you did permanent damage to anything. And always suspect the battery 😉.
