redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Damn. I could have sworn all of the manuals were $99 from that site...now it's $129.99 for 2021. Maybe I missed a sale or something? Also, think it's best just to buy the most recent instead of 2021? Considering it's more accurate and nothing detrimental should have changed. The 2024 is $129.99 and the 2023 is $99.99. Strange.
CarbonSteel
CarbonSteel
Colorado Springs
2023 Carbonized Gray
I updated the transmission pan torque sequence image to indicate the location of the pan studs (6 of them with a 13MM head) versus the pan bolts (12 of them with an 8MM head). The stud locations are circled in red.
@swamp2 + @Poppavein - I am still working on the 3.0L and 2.3L torque values that you sent me. I will ping you when I am close.
swamp2
Such a large and fantastic effort. Take your time. If available I'll take to my mechanic on Monday for my spring spacers 🤘.
Cux211
NE PA
19 ram 2500 Laramie blackout cummins
Ok I give up does anybody know the torque spec for the beadlock beauty ring bolts? Can’t find it
CarbonSteel
CarbonSteel
Colorado Springs
22 ft-lb or 30 nm.
Added along with the torque pattern (on the wheels tab).
Be sure to remove the yellow thread locker from the bolt threads and add a bit of anti-seize to them.
Cux211
NE PA
22 ft-lb or 30 nm.
Thanks 👍
CarbonSteel
CarbonSteel
Colorado Springs
@swamp2 - I have started adding the 3.0 Raptor only torque values in bold red in the sheet. Once I have all of them, I will delete the common values so the Raptor tab only has the unique to Raptor torque values.
@Poppavein - the 2.3L stuff is on deck after the Raptor work is completed.
swamp2
Howdy @CarbonSteel . Did you lose steam on the 2.3 and 3.0 additions?
nolimits
23 Badlands
Alternatively a PDF version of the factory service manual with all diagrams, install procedures, torque specs, etc would suffice. 😉
CarbonSteel
CarbonSteel
Colorado Springs
Oberle
Tennessee
On the front axle it says to discard the drain and fill plug and get new ones. I thought these were reusable.
CarbonSteel
CarbonSteel
Colorado Springs
They are (more or less) standard pipe plugs--totally reusable though Ford says to discard them.
jahwild
Jahsiah
california
Bronco 4-Door
CarbonSteel
CarbonSteel
Colorado Springs
Been looking at this for removing underbody shields to clean out stuck mud and I am curious if the skid plate numbers are accurate. I found this article - https://performanceparts.ford.com/download/instructionsheets/IS_M-5018-BR4_043024.PDF - that references torquing all skid plate bolts to 35 ft-lb but the document here says 35 Nm.
Can someone double check if they have other references?
Reviewing my service manual now and will be making some edits to the torque guide. The values in the torque guide came from a general statement in the service manual. I will edit and add the values for each skid plate.
@jahwild - now updated. Thanks for calling this out. Please let me know if you see anything that I missed.
Skid Plate Torque Values
