Torque Spec Reference List
Bschurr
NY
Must be the center lock wheels. They require 443ft lbs. you have to do it 3 times - torque, back it off, torque and back off and then final torque.
IYKYK
CrystalRedTintCoat
BertJ
Bay Area
‘22 Bronco Wildtrak; ‘13 Camaro 1LE
59 lb.ft, not TTY
Sincere thank you for this. May I ask, how did you find this information? In other words, having been in tech a long time, I feel I ought to have been able to look this up on my own and know the abuse folks get for asking questions rather than RTFM. ;-). Obviously I couldn’t find the answer, and hence my post here.
Ducati1098
I work at a dealership
the poacher
john
Whistler
2010 ford ranger
Inner tie rod: 89 lb. ft
Rear diff cover bolts:
Stage 1: 177 lb. In
Stage 2: 25°
Lower control arm bolts: 210 lb.ft
Trailing arm: 159 lb.ft
Skid plate: 26 lb.ft for metal, 124 lb.in for plastic
Hey Ducati1098,
A question for you regarding the torque spec's for the Rear Diff cover bolts:
- you have stage 1 and stage 2 torque spec's, what are the differences between these two stages? Why are stage 177lb. in, and stage 2 25 degrees? Any insights would be greatly appreciated.
CrystalRedTintCoat
BertJ
Bay Area
Poacher, that sounds like a torque to yield specification to me. 177lbs + 25 degrees more. And never reuse TTY bolts. But, let’s let Ducati have the final say on this one.
Ducati1098
Hey Ducati1098,
@CrystalRedTintCoat is correct.
It’s an initial base torque followed by torque to yield.
The last 25 degrees the bolt will stretch which is what sets its final torque value. Also like mentioned, these bolts cannot be reused. Because once they stretch, it becomes permanent.
the poacher
john
Whistler
2010 ford ranger
Thank you for clearing this up for me, as I was definitely scratching my head. Much appreciated!
EGBUCKER
Joey
2023 Bronco
Does anyone know the torque for the 4 bolts that hold the front wheel hub/bearing assembly to the upright? Sasquatch (if it makes a difference)
Arokcrwlr
Kraig
US - Alabama
2014 F150, 2014 Focus, 1973 Bronco
I believe it is 160 ft/lbs
phillyfx4
Rich
Phila., PA
2008 F 150 4X4
informative post (y)
thanks.....just bought a 2025.....keepin' this thread in my favorites
ApexBronco
Apex, NC
Jeep Gladiator
do you have the torque specs for the body bolts when adding rock rails/steps that use the two body bolts? I have a 2 door. 2023
Valhalla
Valhalla
Chattanooga Tn
Brake caliper retainer bolt torque?
Replacing rear pads next week.
Valhalla
Valhalla
Chattanooga Tn
If what I found is correct the slide pins are 21 ft lb and 46 ft lb for the retainer. Hope someone @Ducati1098 can confirm.
