‘21OBX
90Bronco19
2022 bronco outer banks
Has anyone claimed the stock raptor lights and mounts? Nothing against your guys awesome setups. I find the raptor two light setup pretty clean.
JetG
Jet
TX & FL
2018 Macan Turbo w/PP & 2016 911 Turbo Vert
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Thanks is there any way to do a LP6
Thanks is there anyway to do the lp6 ?
You don't want to run LP6 up there. They are way too big. They are also going to hit the antenna so they won't fit
Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
I mounted my LP6’s on the pillars this weekend and agree 100%. They’re too big for that location, so will be moved to the front bumper. Plus, the glare reflecting off the hood is distracting.
Ford Bronco Bronco Raptor With Proper Lights Setup F6BE4FCD-EAE1-41DC-BA42-AAAD9B04FD85
Raptor911
Raptor911
Broadlands, VA
Their warranty is GOOD. Had an issue with my LP6 and even though I purchased them from 4x4truckleds.com, I just went straight to BajaDesigns and they paid for shipping of 4 LP6s back to them and rebuilt them and sent them back to me.
Good to know. Big fan of their lights. Once my Bronco arrives I will order a set from you guys.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Raptor911
Raptor911
Broadlands, VA
stock raptor lights are not good. It is the same setup on the GEN3 F150 Raptor. Also, I am not sure they will fit the base bronco and also how would you wire them up as 1 pair go to the fog light.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
stock raptor lights are not good. It is the same setup on the GEN3 F150 Raptor. Also, I am sure they will fit the base bronco and also how would you wire them up as 1 pair go to the fog light.
The factory Rigid fogs off a Bronco Raptor will not fit the regular Broncos with HD Modulars. The Bronco Raptor has extra mounting points on the back of the bumper that are required for the rigid fogs (but it's not a good upgrade, better to spend money on a Diode Dynamics or Baja Designs kit)
Raptor911
Raptor911
Broadlands, VA
Thank you for the pic. can you also post the 360 pic?
So how much $$ is the 5 LP4 on the mod bumper? Also can you wire them up separately? For example, 3 to one switch and 2 of them to a another switch. I will be wiring them up to a switch pro.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
It's a 6x LP4 setup. We didn't do a 5x LP4 setup
https://www.4x4truckleds.com/baja-d...4-pro-for-2021-ford-bronco-hd-modular-bumper/
It's $2,899.95 for the 6x LP4 kit.
They are daisy chained to each other but you can certainly buy a 2nd harness if you wanted to put them on 2 switches. Or 2 extra harnesses to have each pair on it's own switch.
Each pair of lights is 15 amps
I don't know 100% if 5x LP4 will fit with the brackets, nor do we plan to try right now unless someone hands us $$ to build the kit :) The truck is already built with 6x LP4 :)
SwampCactus
2022 4 Door Cactus Grey Badlands Sasquatch
Looks so much better than those cheap looking Rigid lights.
vrtical
Doug AI
GSMNP, TN
Fords
This is great, one of the first mods I am doing is addressing the lights.
‘21OBX
90Bronco19
I
I don’t have a base, I’ve seen the raptor lights mounted in a standard bronco mid bumper at a meet so it’s entirely possible. I just can’t warm up to the three lights there. I like the closed off two light setup. If I was going to do it.
Ford Bronco Bronco Raptor With Proper Lights Setup 304C1D15-34FE-44D6-AD9E-A596EDB18110
Raptor911
Raptor911
Broadlands, VA
will not fit .. Per the OP >> The factory Rigid fogs off a Bronco Raptor will not fit the regular Broncos with HD Modulars. The Bronco Raptor has extra mounting points on the back of the bumper that are required for the rigid fogs (but it's not a good upgrade, better to spend money on a Diode Dynamics or Baja Designs kit)
again, the Rigid lights are the cheapest ones they make. If you proper pocket lights then do DD or Baja lights
I
