Bronco Raptor Amp Power Boards
Jltexas
Jon
was curious if anyone has added Amp Power Boards on their Raptor Bronco and if so did you use the standard Amp Boards or the XL Amp Boards? I have the standard power boards on my Wildtrack but was wondering with the bigger tires if the XL would be a better way to go
Darelle
New York State
2021 Ford Bromco Big Bend A51
What's up! Yeah I don't have a Raptor or a wild track I have a big bend. I do have 37s and the XL. It added another 3inches or so to the Amp research steps. I like them alot. I will post pics of my build later this week.
Ford Bronco Bronco Raptor Amp Power Boards 20230213_110751
Ford Bronco Bronco Raptor Amp Power Boards 20230213_110803
Ford Bronco Bronco Raptor Amp Power Boards 20230213_110825
Ford Bronco Bronco Raptor Amp Power Boards 20230213_110840
Ford Bronco Bronco Raptor Amp Power Boards 20230213_111108
Darelle
New York State
Also, this is the measurement of the step extended from the body.
Ford Bronco Bronco Raptor Amp Power Boards 16763049948716172484486519762685
Ford Bronco Bronco Raptor Amp Power Boards 16763050738037151155831755705301
Jltexas
Jltexas
Jon
Thanks that will be much better for my 5 year old twins
Darelle
New York State
Very nice, thanks
Self install was descent and not to complicated. Manufactured directions were a bit shake but I made sure the wiring was done first. It's was the tightest of squeezes in the footwear dropped one of the heads of connector. Took me 20 minutes to dig it out or else I would have had to take off trim to get. The family hated getting into Ripley before I installed. Good luck.
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
I’m curious to know if this fits as well for my Braptor and if so what size. Can you report back if you take the leap? Not sure if the mounting points for the boards are the same with the Raptor but I haven’t done any research
SVTGoat
Maryland
While I have looked at the Amp Research Power Steps for the Bronco Raptor I am actually considering the Go Rhino Power Steps. I have had the Amp Research before on my 2015 F150 and they were nice but I am really liking these. I haven't completed decided if I'm getting any. I may just take the factory steps off and leaving them off.
https://www.gorhino.com/i-30507823-e1-electric-running-board-kit.html
81wedgewood
CD
Texas, USA
I installed the regular boards. I did some trimming on the front fender liner and removed the mudflaps but could’ve just cut about 1” off the board or slide it back further. There’s also a module that needs relocating on the passenger side rear but it’s real simple. Move over a hole and drill a new one. I preferred the clearance rather than the slider look. I have the XL on my Super Duty and don’t like them as much.
Ford Bronco Bronco Raptor Amp Power Boards 1E3217D4-FECF-47D1-9763-67E20E44F31E
Ford Bronco Bronco Raptor Amp Power Boards 88CEBC90-23C2-4452-AA16-404271DFC295
Ford Bronco Bronco Raptor Amp Power Boards FED6848D-C5F6-4247-B649-605151D3E35D
Ford Bronco Bronco Raptor Amp Power Boards D96DB3FE-C703-4DD0-ACD4-7007C639641B
LagoCJ
CJ
Lago Vista, TX
BRaptor and GMC Canyon AT4X
Hey folks...just traded my '21 for a BRaptor and looking to get the XL Powersteps. Their website says that they are not compatible with BRaptor. Looks like Jltexas had success with this setup. Are there known issues to watch out for? What about warranty issues if you 'put them on the wrong vehicle'? (I have an email out to AMP to find out as well...will post the 'official' response when I get it)
