AMP XL Power running boards on my 2023 Bronco Raptor
dblotb
Omar
Redondo Beach
fj cruiser
Yes bronco raptor. Yes those exact cables. I didn’t splice the wires I just shoved them through to connect them. Half way in the install I noticed the amp motors stopped working and it was due the wires getting loose. Which might happen again.
roatanbronco
dave
texas
Audi R8, 23 corvette Z06, bronco outer banks
Excellent! I followed the instructions for the install and powered up after complete and the boards went up and apparently jammed. I disassembled yesterday and had to carefully pry the motors away from the swing arms. I am going to power just the motors like you did today and see what happens. Also my led’s never lit, but I could never get them to go down.
Thanks so much for sharing what you’re doing !! I hope your install goes without incident
dblotb
Omar
Redondo Beach
fj cruiser
Yeah I would take off the motors and test it with just the motors. You might of installed the motors wrong. I still didn’t install the lights. I ran out of time.
dblotb
Omar
Redondo Beach
fj cruiser
Also check your fuse. You might of burnt it out.
roatanbronco
dave
texas
Wow, after repeated attempts to trouble shoot without luck and after being told by AMP their power steps will NOT work on the Bronco Raptor. I figured out the problem was a posi-tap connector. Even though I had stripped the coating from the attaching orange/grey and purple wires ensuring a good connection one of the posi-taps still didn’t make connection. Only after I butt spliced a new wire to the orange and grey wire and make a direct connection did it work!
roatanbronco
dave
texas
Bschurr
NY
Glad you figured it out. No surprise, the culprit was due to your modifications to the factory harness. I HATE those T-taps and other crimp on connections. Splice, soldier, waterproof & wire loom is how factory harnesses should be modified.
vrtical
Doug
GSMNP, TN
Fords
posi-tap connectors suck always have issues with them seating correctly.
