Bronco Light Collision Repair DIY
RoLyMa27
Rodney
SloKart, TX
21 Bronco 2dr, 26 Explorer ST
About a month ago I had a small fender bender that cracked the grille and busted the louvered grill shutters. I am repairing it myself.
I found this part loose. Not sure where it came from. The louvers/shutter part # on the sticker is M2DB-16E166-B. When I search it I keep getting the same part # except with a -A instead of -B. @Ducati1098 or @flip or anyone else with knowledge that might help would be greatly appreciated.
Ford Bronco Bronco Light Collision Repair DIY 1763321531938-98
Ford Bronco Bronco Light Collision Repair DIY 1763321625203-d
Ford Bronco Bronco Light Collision Repair DIY 1763339140160-3f
Ford Bronco Bronco Light Collision Repair DIY 1763338545629-hc
Ducati1098
Not sure what the little rubber bumper is for.
As far as the shutter part number, I’m guessing it’s actually M2DB-16E166-BB, because that is the engineering number of a previous service part number for the shutters.
It’s been superseded twice since that part number. The current one is P2DZ-16138-A
RoLyMa27
RoLyMa27
Rodney
SloKart, TX
Thank you sir. I have searched hi and low and can't seem to find where that thing goes. As far as the different part #'s, they should be interchangeable???
Ducati1098
Yes they should all be interchangeable.
Any of these part numbers will work:
Ford Bronco Bronco Light Collision Repair DIY IMG_9146
Ford Bronco Bronco Light Collision Repair DIY IMG_9147
Ford Bronco Bronco Light Collision Repair DIY IMG_9148
The first 2 you just can’t order from Ford anymore.
totaljustice
Kevin
Middle Sackvegas, NS
Is it a stopper from under the hood?
