Broken tailgate table cable
cmbyrd77
Cory
Orlando, FL
Anyone else in here have the tailgate table installed? Yesterday I was barely leaning on mine and one of the cables broke. Has this happened to anyone else and were you able to replace it? Pics attached for reference.
Ford Bronco Broken tailgate table cable IMG_2792
Ford Bronco Broken tailgate table cable IMG_2791
Ford Bronco Broken tailgate table cable IMG_2790
hk24
Lynn
Ohio
2024 Bronco Big Bend Sasquatch
Take it to your local hardware store, they might be able to make you a new one.
Lynn
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Ford Bronco Broken tailgate table cable 1735009636367-ud
Can you just crimp it back together? You can probably fix it with a cheap piece from a local hardware store.
Worse case you might be able to get a new one through Ford (or whoever actually makes the table), but it probably will be very over-priced.
PetePerkins
Pete
TN
2024 Black Diamond
Goodness, that's a simple enough repair
N2AK
Alaska
1st gen 4runner, 1990 Toyota xtra cab
I had the same end of the same cable slip out of the crimped connection as well. Still have not found a replacement part number to order from Ford. Will go to the local dealership tomorrow to see what they can help me with. This is a case of a bad crimp, not over stressing the table with too much weight. Yes, I could build a new cable assembly myself but I'd like to have some accountability from Ford on a faulty part I paid for.
Neps
Floating off California
MX-5 30th, Focus EV, F150, Scout II (2)
You could cut the heat shrink off and see if the failure was due to an incomplete crimp (swage). You might even be able to reinsert the end of the wire and re-swage.
N2AK
Alaska
Could not find a parts breakdown with the part number of the cable and didn’t make it to the dealership. Tried reinserting loose end into the crimp sleeve but no luck. Cut off the old crimp sleeve, used a new 1/16” crimp sleeve and covered with heat shrink. Looks factory
Ford Bronco Broken tailgate table cable IMG_4406
