Braptor Tailgate Support on Standard Bronco
Rogueshark18
Kyle
Newark, CA
2014 Mustang GT, 1969 F100 4x4, 1969 Mustang Sport
Trying to figure out if the bronco raptor tailgate support would work on the standard tailgate with the standard spare tire mount. Any chance someone has some experience with this? I assume the tailgate is the same and the difference might be the spare mount if anything. Looking to add 37's and prefer the look over some of the aftermarket options.
LAB0035
Lex
2022 Ford Bronco Badlands
I think you can reuse the spare tire mount but you will have to buy the Raptor tailgate hinge Assys along with the tailgate reinforcement. The hinges are expensive
Emmitt
Kevin
Plainfield
Spare tire carrier, tail gate reinforcement and hinges are compatible. I am getting ready do this work also. Just in the process of ordering the parts.
Rogueshark18
Kyle
Newark, CA
So no need for the Raptor hinges? Just need the reinforcement panel?
Emmitt
Kevin
Plainfield
Depends on what you want. If you want full Raptor structural capability then you need the reinforcement, spare tire carrier and hinges. I believe the stock spare tire carrier will also require modifications if you intend on using your existing one with the reinforcement. You will also need the tether and 3rd brake light if you are going with 37s. The Raptor 3rd brake light has marker lights (base doesn't) and thus has a different connector/circuit than the base bronco light assembly. I am not sure what I am going to do there but probably use the marker lights on the same circuit as the brake lights.
Emmitt
Kevin
Plainfield
I also like the Raptor look over some of the aftermarket options.
Emmitt
Kevin
Plainfield
I finished up with the Braptor spare tire carrier, tail gate reinforcement and hinge install today on my BadSquatch. I worked with my local dealer (Rod Baker) and it came out looking good. It does feel very solid. I stayed with my 35s but have the ability to now go with 37s when I feel like it is needed.
The Braptor tire carrier includes the 3rd tail light and does have a different connector due to the addition of marker lights. We left the marker light circuit open and modified the harness with the original connector. I will probably go with a lighted wheel ring when the weather warms up :).
Ford Bronco Braptor Tailgate Support on Standard Bronco IMG_7565
Biggwrm
Orran
Gilroy CA
2018 Raptor
Looks great. I too prefer the look of the raptor over aftermarket options. Mind sharing your parts list?
Tye
Tye
San Francisco
Porsche GT3, Landrover Defender V8, BMW X3 Msport
If you switched to the braptor tire carrier, did you also have to modify the wheel studs as the braptor uses a different stud pattern then the standard bronco.
Emmitt
Kevin
Plainfield
I bought a larger set of lug nuts from a local auto parts store for the spare. I couldn't find a set that were capped and thus the stud threads are exposed to the environment. I put them on for the winter but have a set of capped lug nuts coming in tomorrow from Real Truck - PN RHI-8446LK6-B. Update 4/8: Parts arrived and were the incorrect thread pitch. I want the studs capped before I get out in all of the dust and grime. Your timing is impeccable :)
I also had to account for the spare tire isolator size differences. Both the stock top and bottom isolators had gaps with respect to the contact with tire due to the Raptor having larger tires. You can see the issue with attachment "Gap.PNG" below. I bought a set of furniture pads for the top (see "Stopper Information.PNG" below) and used gorilla glue to attach them to the brake light pad. Kind of crude but you can see the final product in "Rubber Pad Added.JPEG".
For the lower pad I used the Ford isolator/stopper part number M2DZ-1A401-A which is about 3/4 of an inch longer than the production one. It was designed for a smaller tire. I put the part number information and a photo of the final product below.
My apologies for mixing up the stopper/isolator terminologies but I hope this helps.
Ford Bronco Braptor Tailgate Support on Standard Bronco Ga
Ford Bronco Braptor Tailgate Support on Standard Bronco Stopper Information
Ford Bronco Braptor Tailgate Support on Standard Bronco Rubber Pad Added
Ford Bronco Braptor Tailgate Support on Standard Bronco Isolator Updat
