Braptor Rear Diff; gasket or RTV?
Breptar
Max
Los Angeles, CA
Hello,
Anyone here swap out their rear diff fluid yet? The diff cover itself is course and I’m wondering what ford uses to seal it from leaking? Is it a gasket or RTV? If it is a gasket, does anyone have a part number?
Thank you!
Breptar
Breptar
Max
Los Angeles, CA
It has a reusable rubber gasket like the M220 in regular broncos.
PC3Z-4036-AA is the part number.
Is this the same for the braptor? I only ask because the braptor uses a Dana 50 where the other broncos used a Dana 44.
Ducati1098
The part number I posted is for the Raptor, it's the same type of gasket.
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
When I did mine, I reused the gasket, cleaned up the surface and good to go..... pretty easy. I do wish ford made a cover with a drain plug but for as rarely as I'll do this I guess it's ok. My fluid at 25k was pretty clean, I used amsoil 70-140 to refill.
Breptar
Breptar
Max
Los Angeles, CA
I’m actually working with someone to make a billet cover with a drain plug. 😁😉
Breptar
Breptar
Max
Los Angeles, CA
keep it under $300 it will sell.
Honestly, pricing hasn’t come up, but the company I am working with on this only puts out amazing products. The attention to detail is next level, and the materials used are American, so I’m sure they’ll be priced accordingly.
swamp2
Encourage them to copy or very closely imitate the internal shape of the factory unit. It is designed/engineered and tested to produce desirable fluid flow and lubrication. I've seen other units create very poor flow with modified internal shapes.
Well, I suppose alternatively they could embark on a huge independent engineering effort to have their own shape. That seems cost prohibitive and not typical of the off roading aftermarket community, despite how nice of a product they may be making (i.e. not enough engineering...).
Breptar
Breptar
Max
Los Angeles, CA
The stock one was 3d scanned so I am going to guess it will. It was a 3d scan of the inside and outside of the diff cover.
wrs2k
SoCal
Nothing
Are the bolts reusable like the gasket?
Is the front diff using the same type of reusable gasket and perhaps bolts?
I want to refresh diff fluid in both pumpkins at 1K miles. Gracias!
