Bought second rear tow hook from Ford
Nobroncoyet
Ohh
Phoenix
BTW these are made from 6061 aircraft grade aluminum, powder coated, will come in a few different colors, and have the rating laser etched onto them. I was lucky enough to get a pair before they are released in a few days.
Are the bolts rated to 1k pounds as well ?
GI_Jo_Nathan
Jonathan
I feel like they need rollers or something integrated hanging that low.
RowsKing
JR
SJ
22 BRaptor, 66 Stang
I believe they sent the bolts off to get tested. I’m sure when they get released soon they will have more info.
RowsKing
JR
SJ
Factory loops are tilted down at an angle, while these are thicker they go straight out. Most likely not much of a difference. I will get back to you later today when I place my factory next to these.
BuckOffGA
Alan
Atlanta, GA
Ford Bronco 2-Door Manual, Cactus Gray
Thanks for this. I ordered one for my BD ‘22.
Are you able to tell me the size of the bolts - what size wrench will I need to put these on?
Thanks.
The bolts use an 18mm socket.
Mortonm
Canada
2022 Ford Bronco Black Diamond
Add me to the club. Cost seems higher than necessary but its an easy factory option for grab points on both sides. Replacing both with something else would certainly have cost a lot more.
Ford Bronco Bought second rear tow hook from Ford 20230630_113339
anomdeplume
Tampa, Florida
2023 Bronco Base, 2023 Bronco Sport Badlands
Finally! I was so nervous about only having a rear tow hook on the left side. Now, if I get stuck at the mall I won’t have to worry about which parking spot next to me is empty. Tow hook $70 shipped. Peace of mind while shopping for more bucket hats…priceless.
Ford Bronco Bought second rear tow hook from Ford IMG_4213
Docindahouze
Doc
Cumming, GA
Ford Bronco
I got the second two hook also but damn those bolts are on there good, I haven’t installed mine yet. Lol
BBSas
Alabama
Do you want to sell your black one?
Fly
MA
Subaru Outback
59 ft/lbs I believe, a few ugga duggas
Mine was on there wayyyyyy tighter than 59 ft/lbs. Easily over 100 ft/lbs
  • Wow
Reactions: 0ne
