Black Rhino Wheels Thoughts?
Which Black Rhino wheel is best?
  • Abrams
  • Chamber
  • Arsenal
  • Warthog
  • Other?
  • SAS Wheel
Results are only viewable after voting.
Mike777
San Antonio
Ford Bronco, GMC Terrain
I'm looking to do the final mod on my Bronco since I just completed getting a 3 inch lift, 37 in k02, new icon tie rods, and bushings. Want to finish it by getting some wheels with a little more offset than the SAS wheels because of the lift. The ones below are the ones I'm considering. Added some pics of them on Bronco's I found online. Thanks to all who contributed these pics on the forum earlier. Willing to take other suggestions as well!
Abrams
Black Rhino Abrams | Discount Tire
Ford Bronco Black Rhino Wheels Thoughts? 1702410733380
Chamber
Black Rhino Chamber 17 X8.5 6-139.70 0 BKMTXX | Discount Tire
Ford Bronco Black Rhino Wheels Thoughts? 1702410457837
Arsenal
ARSENAL | Black Rhino (blackrhinowheels.com)
Ford Bronco Black Rhino Wheels Thoughts? 1702410561799
Warthog
WARTHOG | Black Rhino (blackrhinowheels.com)
Ford Bronco Black Rhino Wheels Thoughts? 1702410500436
ToddReynolds
Todd
Plant City, FL
2014 Raptor, 2023 Badlands 2 Door
If you already have the 37" tires mounted to your SAS wheels and like them except for the backspacing you can always get some custom wheel spacers from motorsport-tech.com and get the exact custom offset you are looking for.
scotman623
Saratoga Springs NY
Chevy LT Trail boss
I voted Abrams!!Im a Method wheel guy, But I actually like these… Might be a pain to clean if you do alot of off road..
Fordified1
Bob
Mid South Texas
I really like a lot of the Black Rhino wheels.
If you want that hard-core military utilitarian look, Abrams
userdude
Denton, TX
2023 2dr Badsquatch
I like the Glacier, which seems to be about impossible to get.
CarbonSteel
Colorado Springs
2023 Carbonized Gray
Any concerns about brake ventilation or the lack thereof? What about the increase in un-sprung weight?
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Yea, Black Rhinos tend to be heavy… but when you go to 37’s, idk if unsprung weight is really a consideration?
I’m also a vote for Methods, if it matters
Fordified1
Bob
Mid South Texas
The Alpha is one of my faves.
Mike777
Mike777
San Antonio
I actually thought about the weight of the Abrams as well but when I did some research on the forum the weight of the SAS wheels is about 35 lbs and the Abrams are at 34.5 so it's about the same.
I have noticed when I went to 37 k02 brake power went down slightly. I was probably going to upgrade the brakes soon as well anyways since my Bronco is already around 30k miles. The brake kit below was the one I was considering.
Extreme Truck and Tow Brake Pad and Rotor Kits | PowerStop
Dmorty217
Derek
Venice FL
Camery
I vote for the Abrams. When I was picking wheels it were either those or the Armory
Ford Bronco Black Rhino Wheels Thoughts? 70207764892__FC188BE7-365E-4DFE-89A7-B8C38ADC9A25
Mike777
Mike777
San Antonio
Dmorty217
Derek
Venice FL
Camery
Honestly I don’t remember the offset but there is some poke.
CarbonSteel
Colorado Springs
It depends on the 37's. My BFG K02 37x12.5x17 LRC tires were lighter than Kanati Trail-Hog 315/70/17 LRE tires. Given the aluminum parts and while I am not sure of the ball joint durability, I have to assume there is a weight limit that should be considered.
CarbonSteel
Colorado Springs
Don't waste you time or money on PowerStop. Before I upgraded to Teraflex 4 piston calipers and rotors on my Wrangler, I installed PowerStop.
ZERO improvement and a complete waste of money.
BroncoMan24
Carlos
BroncO2403@
Got mine on Mickey Thompson MTZ 305/70/16. Just because wanted to keep the same wheel size! They look sharp! I love how black wheels look, but too many out there already. -10 offset
Ford Bronco Black Rhino Wheels Thoughts? IMG_0761
Ford Bronco Black Rhino Wheels Thoughts? IMG_0762
Ford Bronco Black Rhino Wheels Thoughts? IMG_0760
