Bigger intercooler + charge pipes worth it for 2.7L?
Glen24
Glen
Illinois
24 bronco
Is it worth the $$$ to install a bigger intercooler and charge pipes in the 2.7 broncos.
GA2Dr
Marietta, GA
2024 Bronco 2 DR 2.7
Yes. There are options that bolt in with no mods, including cPE intercooler and CVF charge pipes, which is what I went with (also did Injen CAI at the same time). It really wakes the Bronco up. Pair that with a good custom tune or at least the ProCal and it's a whole different truck.
Valhalla
Valhalla
Chattanooga Tn
Are you looking for more performance? If so and what it gives you is worth the $$$ to power go for it. I did the procal tune and I am happy with my power. I am actually afraid with my use to build more as I do not believe the powertrain is designed to handle to much more once you add tire weight, vehicle weight regear and then push the power in a 4L locked situation. I am waiting on my UFD and Ultimate 60 to arrive so I can use what I already have. If you mostly use it on the road, go for it. 3300 rpm locked and sawing aired down 37's trying to find a bite on wet muddy rock ledges.... snap.
Bellime
Keith
2022 Ford Bronco
Oh man the UD60 is my dream. I am jealous
Bellime
Keith
2022 Ford Bronco
As far as intercoolers. If your going to upgrade your beast, this will be one of many so choose one of the great 3rd party manufacturers.
but I will say, getting bigger charge pipes, intercooler, and intake box at the same time will save you a lot of disassembly/assembly work.
Oldhippie
Barry
Santa Cruz, Calif.
You are not gonna make any/much HP in normal driving with an intercooler but better for long pulls/hard use and it would be my first performance mod (after a tune) then a downpipe for better flow…a cai and catback would be last for me…but the 2.7 does pretty good with just a ford tune for shifting and another $3k+ or so for maybe 50 hp isn’t worth it to me (for now).
telenerd
Laramie
Subaru
Make sure to post up a thread once you get your Dana’s.
Valhalla
Valhalla
Chattanooga Tn
It will be on my build page. They just gave me a date for building them. Should be shipped early September.
Fast Eddie
Ed
NY
2025 4Dr OBX, 2025 Navigator BL
No performance mods make a lot of HP improvements in regular driving. The only real improvement you can make there is programming shift points etc. Power adders really come into effect when going WOT and driving aggressively. I got my CVF charge pipes and intercooler for $990 shipped, not $3k. Great fit and finish and they made a noticeable improvement over stock. As far as I am concerned when combined with a tune it is the perfect setup.
Oldhippie
Barry
Santa Cruz, Calif.
Glad you are enjoying your intercooler & pipes…I said the gains would be at harder use which seldom happens in street driving…but I would like to see actual dyno results showing the gain before plopping down my cash…few manufacturers supply any (or even claim any performance gain)…the $3k+ I mentioned was for the full package of intake & exhaust +tune…my ford tuned 2.7 is not my old 700+hp supercharged mustang but it easily cruises at 85 and has decent enough passing power in most situations so that more performance dollars are low priority compared to actual offroad and camping improvement…but sure, “there is no such thing as too much power”
TruckCamper
Peter
Kingman AZ
Waste of money. Anyone who says different is selling something...
It will only show gains on Dyno or drag strip. Anything else in the real world like: traffic, off road or towing may actually be worse.
I've observed the larger intercooler is slightly slower to heat soak. As in not a game changer time delay. However whatever delay in heatsoak is an equal or greater delay for cooling back down.
Where as the stock plastic charge tubes can never heat soak (as plastic does a poor job retaining or transferring heat). And the stock intercooler cools off much faster and possibly does better in traffic or 4wd slow driving. Not to mention the weight savings of stock!
These mods are for ricer boy cars that don't drive in the real world but enjoy pretending to be "Fast and Furious" cast members.
Ninjak
Miami
I run a bigger intercooler and charge pipes, along with Garrett turbos. I am also custom-tuned. I guess I am one of those ricer boys who think I am in a Fast and Furious movie...but heh, I do live in Miami!
That aside, in a hot climate, these mods will help keep you cooler when using the vehicle. I off-road often on the trails and parks here in S. Fl, and the mods I have do make a difference. When I had my Badlands, I had a full Injen setup along with a FP tune, and I performed better than others in my group who did not have the mods.
The mods are in my sig, but as you can see, you will get varied opinions on this. For me, in real-world case use, the mods make a difference. You need to decide whether it is worth doing for your RIG.
Fast Eddie
Ed
NY
You are entitled to your opinion, even if flagrantly opposite of reality. And being the first person in the world to say a larger and better flowing intercooler and charge pipes may actually be worse is so comical, well I'll just stop there. Best of luck...
TruckCamper
Peter
Kingman AZ
At the same time nobody provides actual data on cooling... we monitor our temperatures and have had stock and aftermarket intercooler.
Just sharing real world observations. Nobody has proven different.
