Best LSD for OB Bronco
Deleted member 32220
Guest
With wheelbase and tires being equal, you got me🤷
Rocketeer Rick
Rick
Rochester, NY
2013 F150 STX 5.0L, 1999 Mustang Cobra
No. If you read my post they both ran Hakka r2. 265/70r17
That's worth noting - I was going to point out that the M/T tires that came on the Rubicon (as I understand) are pretty crappy in the snow, whereas a lot AT tires do OK. But if you eliminated that variable, that helps make a more direct comparison.
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
@Jack D Who makes an LSD for non-Rubi Jeep JL front differential ???
Whoever does would be the ones to ask when they’ll have an LSD for the AdvanTek.
JackD
Jack
Canada
Ranger
Rubi-lockers snd TracLoc which my understanding is Brake Traction like the Bronco has
Sahara-no lockers and Trac lock/Selec Trac which I understand to be brake traction and a true LSD
both on Hakka r2 265/70r17
Rocketeer Rick
Rick
Rochester, NY
TracLoc has long been Dana's trade name for their clutch-type LSD. If the Jeep had a TracLoc, that's what it would be. They would also have brake traction control, as literally just about every car made today has that. At one point, the Rubicon had a lockable LSD in the rear, though I don't know if that's still true.
Guest
Torq makes a d30 front ratcheting locker. It’s been out for about 2 or 3 years now
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Agreed. Brake actuated is plenty for snow. When it gets bad, lock her up. Absolutely best of both worlds.
It actually works quite well too. I didn't get many snow days but I left it in 2wd for most and it got around fine. 4A is really fun in snow though if you want to drive spiritedly.
CodaMojo
Coda
Sacramento
2022 EG Wildtrack, 2014 Ford Escape, 2010 350z
When you see “Best LSD” and misread the post
Rocketeer Rick
Rick
Rochester, NY
Is that for the actual Dana 30, or for the Advantec M186/190 that is often called a Dana 30? Ratcheting lockers are kind of horrible for street use.
JackD
Jack
Canada
Ranger
Ok. Makes sense so
Rubi-lockers and brake traction
Sahara-no lockers and brake traction and LSD
this is my understanding of the stock vehicle systems. (LSD Optioned on Sahara but not avail on Rubi)
Don’t get all Jeep mad at me I’m getting a Bronco and trying to figure out what I will heed to add.
Trilifter7
Ryan
southwest Ohio
2024 F-350 Tremor, 2022 Badlands 7MT
I don't see why the 4A system in Bronco combined with slippery GOAT mode is not a viable answer for this question? Like in the Bronco, a good 4 auto system with good tires should get you thru just about any on road driving condition you would come across confidently.
Rocketeer Rick
Rick
Rochester, NY
Good question
I ask because just like with the rears, people are conflating the names of these axle models. Jeep still says Dana 30, 44, etc. But these new axles are not interchangeable with the earlier ones. The M190 / Dana 30 are a lot more similar to each other than the 44 /M220 though. But still have different splines, bearings and ring gear bolts. And welded ring gears on the Ford M190.
Rocketeer Rick
Rick
Rochester, NY
I think it is a good answer. Just not the best answer. But for a lot of people, its all you need.
kodiakisland
Arkansas
Because he specifically asked about LSDs.
